Bessel Function First Kind: Can Someone Help with C and RK Method?
salla2
Hi everyone, I need some help solving a bessel function of the 1st order. The equation is used to calculate the mutual inductance between two inductors. The equation is:
M=(1.45*10^-8)*integral [J1(1.36x)J1(0.735x)exp(-13.6x)]dx
the integral is from zero to infinity.
Can someone help? please?
Thank you.
Generally for Bessel-functions of order \nu we have the following:
\int_0^{\infty}J_{\nu}(ax)J_{\nu}(bx)e^{-cx}dx = \frac{1}{\pi\sqrt{ab}}Q_{\nu - \frac12}\left(\frac{a^2+b^2+c^2}{2ab}\right)
Here Q_n(x) are legendre functions of the second kind.
For more details check "Watson: A treatise on the theory of Bessel functions" If you need something considering Bessel functions, then its in this book... :D
Thank you.
You asked this before...
https://www.physicsforums.com/showthread.php?t=301041"
The answer is the same... it is not an easy question, if you need to understand the answer, look into the book given by Thaakisfox. It is considered one of the most complete and advanced books on Bessel functions. It will take up a lot of time to read. I use it for looking things up.
coomast
J1(x)=(x/2)[1-(((x/2)^2)/(2*!^2))+(((x/2)^4)/(3*2!^2))-...]
I substituted x with 1.36x for the 1st term in the equation above and 0.735x for the 2nd term in the equation above, then plugged the value of J1(1.36) and J1(0.735x) in
and calculated the value of M from zero to infinity using a TI89 calculator, I was able to obtain the value for M as 2.76585x10^-12
Is this process correct? I also got the book Thaakisfox mentioned from the library today and I'm working to see if there's an alternative solution that I can actually understand. Thank you guys for your help, I appreciate it.
salla2
Hello salla2,
I did this using the software program maxima and got the following output:
2.82623 \cdot 10^{-12}
I assume this will be the same value as the one you have if you would use more terms. Attached is a picture of the maxima console. It is best to use numerical techniques for this kind of integrals especially if you are interested in a numerical value and not as such in a formula. The formula's are often very difficult to handle practically. This does not mean that they do not have any meaning, they are important for theoretical investigations.
best regards,
coomast
anyone could help me with writing a programme to compute bessel function first kind with C
n=0,1,4
aslo soving Bessel Equation first kind by RK method with C
Thread 'Direction Fields and Isoclines'
I sketched the isoclines for $$ m=-1,0,1,2 $$. Since both $$ \frac{dy}{dx} $$ and $$ D_{y} \frac{dy}{dx} $$ are continuous on the square region R defined by $$ -4\leq x \leq 4, -4 \leq y \leq 4 $$ the existence and uniqueness theorem guarantees that if we pick a point in the interior that lies on an isocline there will be a unique differentiable function (solution) passing through that point. I understand that a solution exists but I unsure how to actually sketch it. For example, consider a...
