Bessel function of second kind with integer order.
yungman
I have a question about deriving the Bessel function of the second kind with integer order. I understand that the Bessel function and the second independent variable is defined as:
L(y)=x^2y''+xy'+(x^{2}-n^{2})y=0
y_{2}(x)=aJ_m(x) ln(x)+\sum_{u=0}^{\infty} C_{u} x^{u+n}
and Bessel first kind for integer order is
J_{n}(x)=\sum_{0}^{\infty}\frac{(-1)^{k}x^{2k+n}}{k!(k+n)!2^{2k+n}}
Without going through the series manipulations and factoring out, let me jump to the grouping with terms containing ##a ln(x)##
a ln(x)\left[ \sum_{0}^{\infty}\frac{(-1)^{k}(2k+n)(2k+n-1)x^{2k+n}}{k!(k+n)!2^{2k+n}} + \sum_{0}^{\infty}\frac{(-1)^{k}(2k+n)x^{2k+n}}{k!(k+n)!2^{2k+n}} + \sum_{0}^{\infty}\frac{(-1)^{k}x^{2k+n+2}}{k!(k+n)!2^{2k+n}} - n^{2}\sum_{0}^{\infty}\frac{(-1)^{k}x^{2k+n}}{k!(k+n)!2^{2k+n}}\right]
You can see this is in form of
L(y_{1})=x^{2} y_{1}'' + xy_{1}'+(x^{2}-n^{2})y_{1}
Where
y_{1}=\sum_{0}^{\infty}\frac{(-1)^{k}x^{2k+n}}{k!(k+n)!2^{2k+n}}
My question is in the next step, the derivation claimed
L(y_{1})=x^{2} y_{1}'' + xy_{1}'+(x^{2}-n^{2})y_{1}=0
\Rightarrow\;a ln(x)\left[ \sum_{0}^{\infty}\frac{(-1)^{k}(2k+n)(2k+n-1)x^{2k+n}}{k!(k+n)!2^{2k+n}} + \sum_{0}^{\infty}\frac{(-1)^{k}(2k+n)x^{2k+n}}{k!(k+n)!2^{2k+n}} + \sum_{0}^{\infty}\frac{(-1)^{k}x^{2k+n+2}}{k!(k+n)!2^{2k+n}} + n^{2}\sum_{0}^{\infty}\frac{(-1)^{k}x^{2k+n}}{k!(k+n)!2^{2k+n}}\right]=0
And all these disappeared!
I understand the definition for the Bessel function is
But that does not imply when you see anything like L(y_{1})=x^{2} y_{1}'' + xy_{1}'+(x^{2}-n^{2})y_{1} it is automatically equal to zero. Please explain.
Thanks
I resolve it already. It is very simple
It is given already that
Where
a ln(x)\left[ \sum_{0}^{\infty}\frac{(-1)^{k}(2k+n)(2k+n-1)x^{2k+n}}{k!(k+n)!2^{2k+n}} + \sum_{0}^{\infty}\frac{(-1)^{k}(2k+n)x^{2k+n}}{k!(k+n)!2^{2k+n}} + \sum_{0}^{\infty}\frac{(-1)^{k}x^{2k+n+2}}{k!(k+n)!2^{2k+n}} - n^{2}\sum_{0}^{\infty}\frac{(-1)^{k}x^{2k+n}}{k!(k+n)!2^{2k+n}}\right]=a ln(x)\left[x^{2} y_{1}'' + xy_{1}'+(x^{2}-n^{2})y_{1}\right]=0
Thread 'Direction Fields and Isoclines'
I sketched the isoclines for $$ m=-1,0,1,2 $$. Since both $$ \frac{dy}{dx} $$ and $$ D_{y} \frac{dy}{dx} $$ are continuous on the square region R defined by $$ -4\leq x \leq 4, -4 \leq y \leq 4 $$ the existence and uniqueness theorem guarantees that if we pick a point in the interior that lies on an isocline there will be a unique differentiable function (solution) passing through that point. I understand that a solution exists but I unsure how to actually sketch it. For example, consider a...
