Best conc for an emusifier-methocel K15M)
  • Thread starter Thread starter goku
The discussion focuses on determining the optimal concentration of the emulsifier Methocel K15M for creating a freeze-dried emulsion tablet containing capric acid or triglycerides and the drug thiazide, with maltodextrin in the water phase. Key considerations include the stability of the emulsion, the rate of freeze-drying, and the drug release rate of the final product. It is suggested that while the best concentration may lean towards the lower end for cost efficiency, it should not be at the absolute minimum to accommodate process variability. References to stability and performance metrics are emphasized as critical factors in the formulation process.
goku
if this is the right place to post such ques,( if not then direct where to)
what considerations go into finding the best concertration for an emulsifier- methocel K15M.
my oil phase is capric acid ( or some triglyceride). it is loaded with a drug called thiazide. the water phase has a polysaccaride, maltodextrin. together they are sdupposed to make a freze-dry emulsion tablet.
pls be specific and point to any reference
Chemistry news on Phys.org
I'd say that you should look at the stability of the emulsion as the primary factor. Secondary factors might include rate of freeze drying and drug release rate of the final product. After those are determined, you might have a range of concentration. The best concentration might be somewhere near the lower end (for cost purposes) but not exactly at the end to allow for variability in the process.
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
