Best practices using 555/4017 & many LEDs
  • Thread starter Thread starter Freddythunder
    Leds
The discussion focuses on using 555 and 4017 integrated circuits to control multiple LEDs for a lightbar project intended for film use. The user seeks to illuminate segments of 6-10 LEDs at 30mA each, aiming for a realistic effect with red, blue, and yellow LEDs. Recommendations include using transistors for current amplification instead of relays, as transistors are more reliable and cost-effective. The conversation highlights the importance of selecting appropriate transistors to handle the required current and discusses the feasibility of using driver modules for powering multiple LED strings.
  • Understanding of 555 timer circuits and their configurations
  • Familiarity with 4017 decade counters and their applications
  • Knowledge of transistor operation and biasing techniques
  • Basic principles of LED specifications, including forward voltage and current ratings
  • Research "transistor as a relay" for controlling high-current LED arrays
  • Explore 555 timer circuit variations for LED flashing patterns
  • Investigate LED driver modules like the 4015 BoostPuck for efficient power management
  • Learn about LED current limiting resistors and their importance in circuit design
Electronics enthusiasts, filmmakers, and hobbyists looking to create realistic lighting effects using LED technology in low-budget film projects.
  • #61
Here's an idea if you get printed circuit boards made. Lay it out so each board supports 1x 556, 2x pairs of transistors, and 10x LEDs. When soldering on the blue LEDs, you have one pair of transistors driving 6 LEDs and the other pair driving 4 LEDs. When soldering on yellow or red LEDs, use a few jumper links to drive all 10 LEDs from one pair of transistors, leaving the space for the second pair of transistors empty.
  • #62
Freddythunder said:
I ran a single LED to the 556 to check it's operation and it was working, but nothing was going through the transistors. So I don't think I burnt it out. I will try the new resistor values you suggest. Thanks.
Small signal transistors do get killed without much effort. It is easy to get their leads mixed up. Check that; otherwise, replace it and see whether the circuit starts working.
  • #63
I'll add a note for when you run your circuit off the car's electrical system...
Refer back to the circuit schematic, you'll see capacitor C1. It's there as representative of an attempt to filter potentially destructive spikes that may damage your semiconductors. I suggest that you make C1 using 3 capacitors in parallel to make it closer to ideal: 470uF, 10uF, 0.1uF all in parallel, rated at least 25VW.
If I were building this for myself, I'd use a more thorough filter than this, but as you are working to a tight budget, try those and hope for the best.
Good luck with it. http://imageshack.us/a/img819/7011/smileyi.gif
  • #64
...And then 4 months later...
Hey Nascent, what does putting the caps in parallel do? I've never heard of that, just the difference between putting resistors in parallel vs series changing the overall resistance - does putting caps in parallel do anything besides offer a different capacitance? I have also seen some sort of regulators that put 4 diodes in a circle.. Do you have another idea to clean up the car power. As this project seems to be taking me years to accomplish, maybe I can build a power circuit next July or so...
In other news, I'm learning that soldering is not my strong suit and I get really frustrated doing it! I've posted asking where I could find some hobbiest to do it for me and see the cost to frustration ratio. Any ideas?
  • #65
Welcome back. Again. :smile:
My suggestion for different capacitors in parallel is an attempt to produce behaviour closer to the ideal. While big capacitors (electrolytics) store a lot of charge, they are slow to react, and fast spikes can still get past them. Smaller capacitors are faster to react, so can better absorb fast spikes, but they can't absorb much energy. Placing a few different ones in parallel is a way to get a large capacitance which can still react fast.
I suggested that as a crude protection against transients on the vehicle power supply when the engine is running. If you power the display only while the engine is off, and is kept off, there should be no spikes in voltage.
There are regulator ICs available, or something could be constructed using a couple of transistors, but the circuit you built is probably sufficiently robust that the capacitors will do.
Sorry, I have no suggestions. But if you got those printed circuit boards constructed, the soldering should be as straightforward as possible. When soldering, the surfaces must first be cleaned of oxide, and the soldering iron constantly wiped on wet paper to wipe off the lead oxide.
They say practice makes perfect, though in the case of soldering, it should read "Lots of practice ...". http://physicsforums.bernhardtmediall.netdna-cdn.com/images/icons/icon6.gif
Good luck!
  • #66
It's been a year and a half. Sheesh.. So printed circuit boards are too expensive. I pulled out all of my stuff determined to finish it so I can move on with the script. I even have a proposed camera man who's brother has a old police car to use.
I have six segments constructed and attached to circuits as we have explained. One didn't work. I finally got that one to work and another segment stopped. Along with my patience. :(
Sooo, sometime earlier in the year I was thinking it would be so much easier to just have two 556 circuits, which are working great, the ones that work, and have one drive 40 red, the other drive 40 blue. All the segments have resistors attached so I just need power sent to them. In either case I know that if I run numerous transistors off one 556, I'll blow up the 556. I also have an aurdrino I'm contemplating using to drive it. Can I use a power transistor to drive 40 LEDS at once?
I tried reading this
http://www.sqlskills.com/blogs/paulselec/post/arduino-figuring-out-transistors-and-associated-resistors.aspx
But left een more confused. I know I can only pull so much and can figure how mush current to push... I think.
Can you help a guy one more time :)
  • #67
Disappointed to learn there has been no progress with this. I shall review the thread to see where things stand.
  • #68
Hello Freddy T...
As a different angle - have you asked any of the companies that make these for a "scratch and dent" - or warranty return that is not sale-able? This is for some type of a movie, if I reacall ( I did read through all 4 pages but remeber this thread) - you can offer to put thank you credits in the scroll.
  • #69
It would be cheaper to buy a lightbar from ebay. I started some projects myself in the last couple of years, and after buying all parts, finding out I didn't have the tools I needed, finding out I would do better with other components than the ones I ordered and re-ordering, finding a box for the stuff to fit in, trying to form the box to work the way I want... etc... I ended up spending more than I could have spent buying a used unit.
  • #70
Ouch. Well I did have six segments blinking the way I wanted and the entire shell constructed. I only get about a day a month to work on this with job and fam. But now I'm ready to get this thing finished!
As for scratch and dent I could ask but imnpretty sure it'd be more. I found one one Craigslist for 250 without a controller. That's the best I've seen. I'm only about $100 down. If I can find a way to send power to the segments and control it with my arduino, then I'm set and it will be better than the 555s anyhow. I got the arduino for free so there'd be much less to buy.
  • #71
  • #72
Hello again,
Here is a picture I put together with the values of the resistors and how I put the LEDs together. I'm not exactly sure where in the past four pages I got these diagrams, it's not exact to the post you posted. That was more for the transistor setup I believe.
http://www.themoviecraig.com/files/led-segments.png
After looking at the programming for the arduino and the lack of time I have on just this small piece of the larger project puzzle... I definitely want to change my mind and use the arduino as the processor. The outputs of the arduino are either high or low. So I can program it to toggle hi and low, then shut off for a while. Due to time restraints, I would love to have two of these outputs - connect one to all 40 reds, and the other to all 40 blues.
I figure I can use some solid state method using larger transistors, and tried to research but didn't find anything. I know there are relays, but am afraid they might not be fast enough - but desperate times...
thanks again for your help - I'm soooo close!
  • #73
Trying to use my brain and avoid further frustration, would this work?
If I used the LED calculator I found correctly:
All blue LEDs (at 120 mA Each array) would pull 480mA
All red LEDs (at 60mA each) would pull 240mA
According to this:
http://www.555-timer-circuits.com/increasing-output-current.html
Can I use 1 BC337 for each of the colors off of two of the circuits? One 556 switches a 337 for the blues and the other 556/337 for the reds?
  • #74
Freddythunder said:
Hello again,
Your image seems to show 7 red LEDS in a series string, to be powered by the vehicle battery, nominally 12 volts. Each red LED has approx 2.1v across it, according to your earlier measurements, making a total of 14.7v not including what is required across the current-limiting resistor. I can't see this working. I certainly would not have offered this as a viable arrangement. You can have no idea whether it will work, or what the current will be. Definitely inviting trouble in my opinion.
And it's similar bad news for the blue LEDS if you were to string 4 in series here. :cry:
  • #75
My apologies - the reds are 6 and 4 not 7 and 3... The way I built the thing, the resistor was going in the opposite direction of where I was counting. As for the LEDs, they do all work. I've had 6 of the 8 segments all bliking at once and all segments currently work. I also had a blue one flashing for a few hours; figured if it's going to burn out or blow up, I'd see something then.
  • #76
Project Finished!
Here we are again... One year and four months later.. Of course I think probably closer to a total of about 15 hours in that time span.. And it is finished.
I wound up putting together two 556 circuits and connecting the output to a TIP31 transistor for 4 segments of LEDs each. The circuits are currently in a breadboard, but for the time being, I think it will probably stay like that. I finished wiring up the lightbar and ran about 6 feet of wire off the end so that I can connect it to anything later if I change my mind, solder circuits together, get printed circuit boards, box up the breadboard, or any other option.
NacentOxygen, thank you for your help over the year!
I decided that with by budget constraints of not being able to spend anything else on this, I can take some strong magnets I have from projects past and be able to stick it to a metal car roof.
I also learned that driving around with those lights on my car WHEN THEY'RE OFF is illegal - so I'm glad I found that Arizona Revised Statute! (28-947) So when I do go and film, it will have to be on private property and I'll have to transport it in my trunk or something.
https://www.youtube.com/watch?v=VD2Qc26BAn4
  • · Replies 49 ·
22K
