Bab5space
- 111
- 13
Rocketry is not good enough for the standard scifi spaceship that can take off and land like it pleases with high payloads.
Yet I still like rocketry because I like the fiery exhaust plumes. So I am considering linking the spaceship's rocket engine to a portal linked to to a planetary propellant depot. Feed the ship up to 7 light seconds out max.What does this do for storyverse?
1. SSTO spaceships are now easy to make, just be willing to foot the propellant bill.
2. The moon can be used as a base once propellant depots are set up and portals attached. Extending range from the home planet even further (14 light seconds of propellant out). The only difference is that 7 light seconds out you could only be portal fed moon made propellant.
Now I know processing can be made a lot easier on the moon since we have portals to transport water from Earth to make some nice moon propellant combos.But if I add warp and hyperdrives into the equation and they go to unexplored places what do they do?
Find a moon to set up propelant depots and then fly to the local planet with it.
Assuming they were in a hurry and did'nt want to process the propellant to get better efficiency, how efficient would moon regolith (moon dirt) be? Provided it was thermally propelled with nuclear power?
If it is inefficient, then the moon propellant depot will need either a lot of dirt stashed on a conveyor belt headed for a portal, or a lot of heavy duty tractors dumping the raw regolith into portals.
If efficient, it will take less propellant mass per unit of thrust (unlikely since we are not even procesding the propellant).What are othet sources in the solat system that offer efficient proppellant sources youcan good efficiency out if without procssing it?
