Best type of wire for magnetic field?
For creating a magnetic field with wire, both enamel copper wire and aluminum wire can be used effectively, as the strength of the magnetic field primarily depends on the current flowing through the wire. While enamel copper has better conductivity, the overall performance of either wire is similar when proper impedance is in place to manage current flow. It's crucial to ensure that the wire does not overheat or damage the power source. Ultimately, either wire can achieve the desired magnetic field strength if the current is controlled appropriately. The choice between the two may come down to practical considerations like insulation and handling.
hyperion4
I'm looking at getting a lengthy piece of wire, looping it around into either a circle or an ellipse and running a current through it to get a magnetic field, however I'm unsure what type of wire to go for? There's enamel copper wire and the standard aluminum wire. Which one will give me the better, or stronger, magnetic field? Thanks.
The magnetic field will be determined by the amount of current flow through the wire.
However, a single wire has a low resistance and can either burn out your power source, or heat up so much that it starts a fire. Have you ever worked with electronic circuits before at all? Do you know Ohm's Law?
Yes I'm familiar with all of that. This is for a 3rd year electromagnetism course. We have the necessary impedance in place. Just wondering which type of wire is best suited for a magnetic field? I think it's the enamel copper, but just want to confirm.
To my limited knowledge, neither wire is "better". The magnetic field will depend only on the amount of current, which in turn depends on the voltage applied and the resistance of the wire. Of course, an enameled wire may be preferable to a bare one, since you don't have to worry about it shorting out if something touches it.
Hmm perhaps you're right. I just thought that the wire with the better conductivity would be 'best', which in this case is the enamel copper.
Since you said you already have your impedance set up, then I assume you plan on limiting the amount of current flow through the wire. In this case I'd say that either of them will work fine. You can always increase or decrease the impedance if you want more current flow. But neither wire is really any better than the other in terms of supporting a magnetic field.
Thanks for that.
