Best type of wire for magnetic field?
The discussion centers around the selection of wire types for generating a magnetic field by running current through a looped wire, specifically comparing enamel copper wire and aluminum wire. The context includes considerations of electrical properties and safety in an electromagnetism course setting.
  • Technical explanation, Debate/contested
  • One participant inquires about which type of wire, enamel copper or aluminum, would produce a stronger magnetic field.
  • Another participant emphasizes that the magnetic field strength is primarily determined by the current flowing through the wire, which is influenced by voltage and resistance.
  • A participant confirms familiarity with basic electrical principles and seeks validation on the choice of enamel copper wire for its presumed advantages.
  • One participant suggests that neither wire is inherently "better," noting that the magnetic field depends on current rather than wire type, while also mentioning the safety aspect of using enameled wire to prevent short circuits.
  • Another participant expresses a belief that better conductivity would lead to better performance, specifically favoring enamel copper wire.
  • A later reply reiterates that either wire would function adequately, given that impedance is already managed, and concludes that neither wire is superior for generating a magnetic field.
Participants generally agree that the magnetic field is determined by current flow, but there is no consensus on the superiority of one wire type over the other, as opinions vary regarding conductivity and safety considerations.
Participants reference basic electrical principles such as Ohm's Law and impedance management, but there are no detailed discussions on specific resistance values or other quantitative measures that could influence wire selection.
hyperion4
I'm looking at getting a lengthy piece of wire, looping it around into either a circle or an ellipse and running a current through it to get a magnetic field, however I'm unsure what type of wire to go for? There's enamel copper wire and the standard aluminum wire. Which one will give me the better, or stronger, magnetic field? Thanks.
The magnetic field will be determined by the amount of current flow through the wire.
However, a single wire has a low resistance and can either burn out your power source, or heat up so much that it starts a fire. Have you ever worked with electronic circuits before at all? Do you know Ohm's Law?
Yes I'm familiar with all of that. This is for a 3rd year electromagnetism course. We have the necessary impedance in place. Just wondering which type of wire is best suited for a magnetic field? I think it's the enamel copper, but just want to confirm.
To my limited knowledge, neither wire is "better". The magnetic field will depend only on the amount of current, which in turn depends on the voltage applied and the resistance of the wire. Of course, an enameled wire may be preferable to a bare one, since you don't have to worry about it shorting out if something touches it.
Hmm perhaps you're right. I just thought that the wire with the better conductivity would be 'best', which in this case is the enamel copper.
Since you said you already have your impedance set up, then I assume you plan on limiting the amount of current flow through the wire. In this case I'd say that either of them will work fine. You can always increase or decrease the impedance if you want more current flow. But neither wire is really any better than the other in terms of supporting a magnetic field.
Thanks for that.
  • · Replies 22 ·
  • · Replies 27 ·
  • · Replies 61 ·
