Bifilar pendulum experiment
The bifilar pendulum experiment demonstrates that the data aligns closely with theoretical predictions. A key inquiry raised involves the expectation that the period of a bifilar pendulum should match that of a torsional pendulum when the support strings converge at a single point, indicating zero separation. However, the participant struggles to derive the bifilar equation to align with the torsional equation in this limit. The distinction between the restoring forces of a torsional pendulum and a simple ball-on-string pendulum is also highlighted, emphasizing the role of rotational elasticity over gravitational forces.
  • Understanding of bifilar pendulum mechanics
  • Knowledge of torsional pendulum dynamics
  • Familiarity with restoring forces in oscillatory systems
  • Basic principles of rotational elasticity
  • Research the mathematical derivation of bifilar pendulum equations
  • Study the mechanics of torsional pendulums in detail
  • Explore the concept of restoring forces in oscillatory systems
  • Investigate the ball-on-string pendulum problem and its implications
Physics students, mechanical engineers, and hobbyists interested in pendulum dynamics and experimental mechanics will benefit from this discussion.
houlahound
Bifilar pendulum, data matches the theory real neat. Do have a question, I would expect the period to match the period of a torsional pendulum for the limit when the support strings are the same point ie zero separation.
I can't get the bifilar equation to reduce to the torsion equation for said limit. Any clues?
if the 2 pendulum strings are attached at the same point, it has become a simple ball-on-string pendulum.
(the bifilar's ball motion is the same as for a single string, if the string is shorter.)
A torsional pendulum's Restoring Force is caused by a thick support's rotational elasticity, rather than gravity.
Not aware of the ball on string problem, google gave ambiguous results. Do you have link?
10K
10K
