Quantizing GR to Fix Big Bang Singularity: Research Roundup
  • Thread starter Thread starter marcus
    Big bang
marcus
Homework Helper
Dearly Missed
Really should call it "Big Bounce" instead of Big Bang.
Yesterday another paper was posted at the Los Alamos arxiv
about getting rid of the Big Bang glitch by quantizing General Relativity.
Martin Bojowald started this line of research but more people are getting into it, the new paper is by a guy at Hamilton College and someone in the Czech Republic
http://arxiv.org/abs/gr-qc/0309035
"Isotropic Loop Quantum Cosmology with Matter II: the Lorentzian Constraint"
Franz Hinterleitner (Masaryk University, Brno) and Seth Major (Hamilton College)
The essential thing here is that (by failing at certain points) classical theories sometimes predict their own replacement by quantized versions. GR does this by breaking down at the time zero singularity (BB) and failing to compute.
There are historical parallels-----in 1900 Planck came up with a theory of thermal radiation (the first quantum theory of anything) that cured a "singularity" in the classical theory of how hot objects radiate-----the classical unquantized theory suffered from infinities, failing to compute sensible answers at either very short or very long wavelengths. Not too long after that Bohr came up with a quantum theory of the hydrogen atom which cured another classical glitch---the unquantized theory predicted absurd results at a certain point and he fixed the bug.
Sometimes by having glitches, a classical theory will show it needs to be quantized, and quantizing it sometimes fixes the bugs. The Big Bang is a glitch in GR. Quantizing GR in a minimal way (not adding new structure besides what is necessary to quantize the basic equations of GR) gets rid of the trouble at time zero (and also predicts inflation without having to add any new particle or field, just from a quantum geometrical effect of ordinary matter)
So there are a bunch of papers cropping up about this and more people getting into it. Here are some names in no particular order of people who (since Bojowald started it) have published about loop quantum cosmology getting rid of the big bang singularity and/or deriving inflation as a result of loop-quantizing GR
Ashtekar
Lewandowski
Bojowald
Smolin
Stephon Alexander (SLAC)
Golam Hossain (Chennai, India)
Gambini
Pullin
Seth Major
Franz Hinterleitner
doubtless I've missed some
Hossain's paper was mainly about getting inflation
by loop-quantizing GR, but incidentally gets rid of BB singularity.
Marcus, I've been wondering about something. If both LQG and M-Theory postulate a "Big Bounce" (as you call it), then is it possible to unify both theories?
that is something which interested young people like yourself will have to determine----perhaps other PF posters have ideas
I can only comment at level of inconclusive detail
LQC does not "postulate" a bounce
it is the result of calculating a wave function evolving across the classical singularity
the math is pretty simple: all standard cosmology is based on two short diff eqns called Friedmann eqn, if you (loop) quantize them you get again a comparatively simple difference equation model and it does a bounce (changing from contraction to expansion) right at the point where the classical Einstein/Friedmann model blew up
The people who worked it out---Martin Bojowald, Abhay Ashtekar, et al---call it a bounce (I did not hear them say "Big Bounce" actually, but they do say bounce). It is not my choice of term.
There is an incredible difference between LQG and other approaches which it will help to understand. LQG is extremely conservative----bare bones quantization of GR with no additional structure beyond what is required by quantization----no "creative" elements---no "branes" and no "extra dimensions" and "ToE"stuff.
It is the bare minimum and people have been trying to quantize GR for several generations (since before 1950) and there'v been technical obstacles and they'v finally gotten over some of the obstacles and it's beginning to work.
There is a small set of versions of LQG and they are all beginning to predict numbers that will allow them to be tested and some will be rejected and modified----the cycle of prediction and experimental test will help the development.
The bounce in cosmology is a robust result in the sense that it is predicted by any version----LQC is a simplification of LQG so whatever version of the full theory boils down to very similar versions of cosmology all with the same qualitative behavior.
It is very hard to compare this rather concrete, limited nuts-and-bolts result of doing a standard ("canonical" they call it) quantization job on 1915 GR with "M-theory" which seems a total opposite-----highly un-conservative, non-predictive, proliferated into a huge variety of versions none of which corresponds to reality in any obvious way. Different animal(s) I'd say.
How are you on the key concept of background independence?
The 1915 General Relativity theory is fully background independent----invariant under diffeomorphisms (smooth transformations of the manifold). It is an awfully important feature of GR that many people fail to recognize.
LQG preserves the background independence feature---it is also a background independent theory, like GR itself.
This is why it is so hard to compare LQG to stringy theories. Or to draw any solid connections. The connections tend to be spurious, specious ones "this contains that" when it doesn't really contain it except in some superficial way.
to understand the basic theoretical layout you need to assimilate the background issue. unfortunately. seems to be a major hurdle for a lot of people
One point on that though: If it is just bare-bones quantization of GR, then there could really be no unification between it and M-Theory, but rather an assimilation of it into M-Theory, if that's even possible (there is the background-depency issue, which seems to be a big hurdle, but I've had difficulty seeing why (I don't completely understand what is meant by "background indepence")).
Very true, I'd say that M-Theorists are after the big prize right away (as was Einstein, before he died), and they may need to start taking smaller steps.
So, let me get this right, "background independence" is basically just the preservation of invariance under diffeomorphisms? So, what is it about string theories that calls for "background dependence"? IOW, what is it about string theory that implies a background-dpendent structure?
Yeah, that's what I always hear about, but I have apparently not studied string theory enough to see why it should be "background-dependent".
Perhaps you could help me out on that?
Another question that pops up is how you go from a universe that expands at an accelerating rate to a contracting universe to allow a bounce in the first place. It would still appear that the universe has a beginning (no singularities though), unless there is some mechanism to stop the expansion and reverse.
I think I see your point Eh and I haven't personally seen any answers to that suggested in the limited context of loop quantum cosmology.
There are more imaginative papers that play around with the idea that "dark energy" could decay and even go negative so that expansion stops accelerating and even reverses and the cosmos contracts. So there is some "cyclic" expansion contraction expansion process.
But for me the value AND the limitation of LQC is that it is rather conservative, unimaginative, minimalist----it just wants to quantize the standard classical Einstein or Friedmann model with the least amount of extra assumptions and machinery and just see what logically results from doing that
there is a real value to both approaches (a wide ranging highly imaginative approach and a conservative kind of grudging cautious one that clings to classical GR and only changes enough to quantize it in the traditional way). Human mental diversity. Sometimes I am very glad to belong to this species with all its
different ways of looking at the world. But right now I'm personally most excited by what seems to be coming from the
minimalist approach of (canonical) quantizing GR. Want to get to replying to Mentat but will get back to this train of thought with you I hope
Mentat, frankly your question that I quote here is one of the keenest if not the keenest I've ever seen on PF and I say this not as a compliment but because it is a relevant fact. It would be very exciting to me if some person (say selfAdjoint) would suddenly appear and answer this really major question which you pose:
"what is it about string theory that implies a background-dependent structure?"
IIRC in one of Tom Bank's thoughtful overview papers (Critique of pure string theory) he indicates that at one time there was a hope of formulating a string-ful theory in a background-indep way and in that paper he discounts that hope saying that it probably just isn't going to happen. For what that's worth. we don't have to take Banks as gospel!
Anyway, there might be a simple answer to your question! Maybe someone will just walk in and say "well the equations for vibrating strings just need a definite background" or "well you have to start with a fixed space just so you can define the basic objects" or something. Or someone will come in and amaze me with the news that so-and-so has defined a B-I version of some variant of string so it is possible after all!
But for now all I feel capable of is just echoing your question, with this quote:
[[here you quote my previous post:
to understand the basic theoretical layout you need to assimilate the background issue. unfortunately. seems to be a major hurdle for a lot of people]]
I'll try to reply more adequately later today.
Maybe the nittygritty of how equations can be invariant under
various kinds of transformations should be discussed
Actually it is pretty amazing to me that the Einstein GR equation is invariant under diffeomorphisms because they really can mix points around and deform a manifold almost beyond recognition, intuitively it is a radical sort of invariance or as a mathematician might put it a "strong" form of invariance---an extreme thing to demand of theory. Between 1912 and 1915 Einstein had decided not to have it and he waffled (even tho in a race with Hilbert he wasted time waffling) and then in 1915 he went for it. Have to go to lunch but will return to this. Thanks for great question
__________________
Well, according to M-Theory, the Universe is not expanding or contracting, it's doing both. This is a result of the t duality, which I've brought up on numerous threads before.
The 3 large spatial dimensions are still expanding, and will forever. In the ekpyrotic (or cyclic) model, our universe of infinite volume expands forever, but it is the collapse of an extra dimension that produces the effects of the big bang. LQG doesn't have any extra dimensions to resort to, so some kind of other mechanism would be needed to half the expansion in that area.
Objection! Speculation.
There is no reason why this must be true, Eh. Of course, it might be, but then M-Theory would be disproven
I don't understand what this means. Can you expound?
Also, M-Theory predicts that the other "wrapped up" dimensions are contracting, as the 3, that we are used to, expand. Thus, the so-called "bounce" effect (in M-Theory) is really just the idea that, once space reaches the Plank's size it will no longer be measurable in terms of vibrating strings, and must be measured in terms of wound strings, which would then be expanding.
I'm using the assumption string theory is true, and the cosmological constant will remain positive. M theory would not be disproven by an ever expanding universe.
I'm referring to the brane collision model. http://feynman.princeton.edu/~steinh/
M-Theory predicts a cycle, like the one mentioned in the link your provided. This cycle requires that there be a Big Crunch, and then another Big Bang, and then another Big Crunch, etc...forever.
I don't think the cycle is a required part of M theory. But I would like to know where you read that it is.
