I Bijectivity of Manifolds: Can m≠n?
  • I
  • Thread starter Thread starter kent davidge
    Manifolds
kent davidge
Is it possible for a manifold to be homeomorphic to ##R^m## in some regions and homeomorphic to ##R^n## in other regions, with ##m \neq n##?
This depends on how you define a manifold. Let's say that we only assume it to be locally Euclidean. Then the two parts cannot be connected, as this would lead to a point, where it isn't Euclidean anymore. But if we allow more than one component, then it is possible, although we would probably investigate each of the components on their own.
Likes dextercioby, Matterwave and kent davidge
To just expand on fresh_42 a little, I quote from wikipedia:
Generally manifolds are taken to have a fixed dimension (the space must be locally homeomorphic to a fixed n-ball), and such a space is called an n-manifold; however, some authors admit manifolds where different points can have different dimensions.[1] If a manifold has a fixed dimension, it is called a pure manifold. For example, the sphere has a constant dimension of 2 and is therefore a pure manifold whereas the disjoint union of a sphere and a line in three-dimensional space is not a pure manifold. Since dimension is a local invariant (i.e. the map sending each point to the dimension of its neighbourhood over which a chart is defined, is locally constant), each connected component has a fixed dimension.
Since this question was posed in the physics (SR/GR) sub-forum, I will specify that generally we consider only a "pure manifold" when doing physics. This is because if you have a disjoint union of two sets as your "manifold", then those disjoint unions can't actually interact with each other. There's no path that takes you from one to the other. You can't send signals between the two, and so, for observers in one manifold, the other manifold might as well not exist.
Likes dextercioby, kent davidge and Ibix
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
