Calculating Probability for Bingo Game: 4 Corners, Row, and 2 Rows
  • Thread starter Thread starter haplo3
    Game Probability
The discussion focuses on calculating the probabilities for a Bingo game scenario involving a 5x5 card with 25 numbers, where 45 balls are drawn from a total of 80. The probability of getting all four corners is derived from the combinations of the remaining balls, calculated as C(76,41)/C(80,45). For any row, the initial approach suggests multiplying the corner probability by 5, but this method overestimates by including combinations of multiple rows. A revised formula is proposed to account for the overlap of probabilities when considering multiple rows, indicating a need for careful adjustment to avoid double counting. The conversation emphasizes the importance of accurate probability calculations in game design.
haplo3
Hey all,
have a problem to solve for my new game game. really appreciate if someone can help me solve this issue:
* i need to calculate the probability for a given combination
1. Total number of balls in the box = 80
2. Total number of chosen balls 45
3. for simplicity we have only 1 card 5x5 (25 numbers in total)
question
what is the probability that i will get
a. 4 corners of the card?
b. any row ?
c. any 2 rows?
if someone can give me a start i will be happy
Here's a start. I'm assuming you are holding the card and the 4 corners are known. There are C(80,45) possible combinations of 45 drawn from 80. There are C(76,41) combinations that contain your 4 corners so the probability of getting all 4 corners is C(76,41)/C(80,45). Any row is similar except that there are 5 of them, each containing 5 numbers. Give it a try.
thank you very much. for the rows because i can get 5 different combination
(c(76,41)/c(80,45))*5
is that correct?
i assume not cause it includes the probability of getting 2 rows together or 3 rows or 4 rows, right?
is this the correct answer for 'any row'
(c(76,41)/c(80,45))*5 - ( (c(76,41)/c(80,45))^5 + (c(76,41)/c(80,45))^4 + (c(76,41)/c(80,45))^3 + (c(76,41)/c(80,45))^2 )
so change of getting a row multiply by 5 = this will give me the chance of geting 1st OR 2nd OR 3th OR 4th OR 5th
but will also give me AND 5,4,3,2 rows together - there for i deduct those
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
