Expand (1-6x)^4 (1+2x)^7 - Solve Binomial Expansion
The discussion focuses on expanding the expression (1-6x)^4 (1+2x)^7 up to x^3. The initial expansions of both binomials are presented, with (1-6x)^4 yielding 1 - 24x + 216x^2 - 864x^3 and (1+2x)^7 resulting in 1 + 14x + 84x^2 + 280x^3. The user attempts to combine these expansions but arrives at an incorrect final result of 1 - 10x - 252x^2 + 2240x^3. Other participants point out that there is a missing term and errors in the addition of the x^3 coefficients, indicating that the correct answer should be 1 - 10x - 36x^2 + 424x^3. The discussion highlights the importance of careful term combination and coefficient calculation in binomial expansions.
Fly_High
Expand (1-6x)^4 (1+2x)^7 in ascending powers of x up to and including the terms in x^3
(1-6x)^4 (1+2x)^7
Firstly, I expand (1-6x)^4
= (1)^4 + 4C1 (-6x) + 4C2 (-6x)^2 + 4C3 (-6x)^3 + ...
= 1 + 4(-6) + 6 (36x^2) + 4(-216^3) + ...
= 1 -24x + 216^2 - 864x^3 + ...
Then after that, I expand (1+2x)^7
= (1)^7 + 7C1 (2x) + 7C2 (2x)^2 + 7C3 (2x)^3 +...
= 1 + 7 (2x) + 21 (4x^2) + 35 (8x^3) + ...
= 1 + 14x + 84x^2 + 280x^3 + ...
Finally, I expand (1-6x)^4 (1+2x)^7 together...
= (1-24x+216x^2=864x^3+...) (1+14x+84x^2+280x^3+...)
= 1+14x+84x^2+280x^3-24x-336x^2-2016x^3+3024x^3-864x^3+...
= 1 -10x-252x^2+2240x^3+...
My final answer is wrong.:frown: It should be 1-10x-36x^2+424x^3+...
Can someone help me solve this? Thanks.:-p
That's OK
= 1+14x+84x^2+280x^3 OK
-24x-336x^2-2016x^3 OK
+3024x^3-864x^3+... That's where you went wrong. There's a term missing, and probably you made another mistake adding up the terms because I can't see how you got 2240x^3 from your (wrong) numbers.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
