BJT single stage amplifier we write gm=Ic/VT
  • Thread starter Thread starter pforpashya
    Amplifier Bjt
In a BJT single stage amplifier, the transconductance (gm) is defined as Ic/VT, with VT being the thermal voltage of approximately 26mV. For a Darlington pair configuration, the overall gm is calculated using the combined thermal voltage of 52mV, as there are two forward active PN junctions. Each transistor's gm is determined by its own collector current divided by its respective VT. The small signal gain for a common emitter amplifier can be expressed using the parameters of both transistors in the Darlington pair. Understanding the inclusion of the Boltzmann constant in VT calculations is essential for accurate thermal voltage representation.
pforpashya
For BJT single stage amplifier we write gm=Ic/VT where VT is Thermal voltage whose value is 26mv. Now if we have a Darlington pair i.e. two transistor connected in CC-CC mode what will be overall gm.
Will the collector current Ic be divided by 52mv or 26mv. (Because in gain equation gm comes)
as their are two forward active PN junctions ...the cumulative change in VT is 52mV?
is this correct?
can someone through light on "why we have to include Boltzmann constant in calculation of VT"
in simple words?
Thanks in advance
Each device has gm value equal to its own Ic divided by VT, where VT is 25.7 mV for each device. For a Darlington, if the input device is no. 1, and output device is no. 2, then Ie1 = Ib2, Ic1 = α1*Ie1, Ic2 = β2*Ib2, or Ic2 = α2*Ie2, .
This should get you started.
Claude
ok. thank you for your reply. to find overall gm (i.e. gm2 as gm1 of first pair in darlington is very small) of the device should i divide Ic2 by VT1+VT2 i.e. 52mV?
Yes you should use 2*Vt if you want to find voltage gain.
The small signal gain for CE amplifier is equal to
\Large \frac{Vout}{Vin} =-\frac{Rc (\beta 1+\beta 2+\beta 1 \beta 2)}{(1+\beta 1) (re1+re2+re2 \beta 2)}
Where
re1 ≈ 1/gm1
re2 ≈ 1/gm2
Likes 1 person
Thanks alot...I have to solve one unsolved problem on darlington pair before saturday. I hope i will get right answer as i have to just multiply gm by output resistance of darlington pair.
in simple words?
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
