Black hole acreting binary -magnetic fields
In black hole accreting binaries, the distinction between weak and strong magnetic fields affects how material is funneled towards the black hole, similar to white dwarf binaries. While a Kerr black hole is expected to have a strong magnetic field and powerful jets, the lack of a solid surface complicates the understanding of its accretion disc and energy radiation. The Membrane Paradigm suggests that an "apparent surface" allows for the attachment of a magnetic field, despite the absence of a physical surface. This leads to questions about how material can lose angular momentum if it does not form an accretion disc, as it would in the presence of strong magnetic fields. The discussion highlights ongoing challenges in understanding black holes and their properties, particularly regarding magnetic fields and accretion dynamics.
skydivephil
In a white dwarf acreting binary we would make distinction between thsoe with weak magnetic field that make an acretion disc and those with strong magentic fields where the material from the larger star gets funneled along the field lines.
But in a black hole binary all of the energy is released at the acretiion disc. But what does that mean for the magentic field of the balck hole. Does it have a magentic field? If so how does that affect the way the matieral would be chanelled?
Astronomy news on Phys.org
A good question! A Kerr black hole [the most likely species] should have a strong magnetic field and powerful jets, but, our technology is still a little too primitive to yield convincing data.
Thanks Chronos, but is there a theory that's accepted? Normally when there is a strong magentic field the larger stars material can't cross the field lines and so does not form an acretion disc. Instead it gets tangled on the field lines and goes straight to the comapct star.
But the black hole must radiate its energy at the acretion disc as it has no solid surface so I see a problem here, is there any consensus resolution?
Well, we still have a hard time making the case for the existence of black holes, much less properties of their accretion discs. If its any consolation, we have strong evidence for the existence of condensed matter objects [e.g., neutron stars] with powerful magnetic fields.
Yes.
There is something called the Membrane paradigm. Essentially even though the black hole doesn't really have a solid surface, the fact that from the point of a distant observer, it *appears* that matter is freezing just before it enters the black hole, gives you something that acts like a solid surface that you can attach a magnetic field to.
http://en.wikipedia.org/wiki/Membrane_paradigm
The "apparent surface" of a black hole still acts quite differently from a real surface. The big difference is that when you drop a lot of matter onto a neutron star, it hits the surface and creates a massive burst of energy. The "apparent surface" of a black hole let's the matter fall through, and from a distant observer it appears to freeze, which means that you won't get any bursts.
Im thinking more of what happens to the material before it falls down the black hole. In white dwarf binaries for example it doesn't have to form an acretion disc. if there are strong magentici fields then the material infact wotn form an acretion disc but will travel along the field lines to the white dwarf.
So it seems the same would happen to a black hole if it has strong magentic fields. The problem is , hwo can the material lose angualr momentum if not at the acretion disc?
UC Berkely, December 16, 2025 https://news.berkeley.edu/2025/12/16/whats-powering-these-mysterious-bright-blue-cosmic-flashes-astronomers-find-a-clue/ AT 2024wpp, a luminous fast blue optical transient, or LFBOT, is the bright blue spot at the upper right edge of its host galaxy, which is 1.1 billion light-years from Earth in (or near) a galaxy far, far away. Such objects are very bright (obiously) and very energetic. The article indicates that AT 2024wpp had a peak luminosity of 2-4 x...
  • · Replies 30 ·
  • · Replies 17 ·
  • · Replies 48 ·
  • · Replies 44 ·
  • · Replies 25 ·
