Understanding Matter and Antimatter Interactions in Black Holes
  • Thread starter Thread starter Unredeemed
    Black hole Hole
Matter and antimatter interactions in black holes do not equate to antimatter leaving as matter enters. Both matter and antimatter increase the mass of a black hole when they fall in, while Hawking radiation, which can include antimatter, decreases its mass. Annihilation between matter and antimatter inside a black hole does not affect its total mass due to conservation laws. Antimatter is defined as particles with opposite quantum numbers to their matter counterparts, such as positrons compared to electrons. The discussion highlights the complexity of these interactions and the fundamental principles governing them.
Unredeemed
Is matter going into a black hole the same as antimatter leaving one?
This has confused me for a while...
Thanks,
Jamie
Astronomy news on Phys.org
No.
Matter and antimatter falling into a black hole increase the mass of the black hole. Matter and antimatter "leaving" (Hawking radiation) a black hole decrease the mass of the black hole.
But wouldn't the antimatter and matter anihilate one another inside the black hole?
My point was that since matter falling into a black hole increases the black hole's mass and antimatter leaving a black hole decreases a black hole's mass, these two processes are not the same
Only if their worldlines intersect inside the black hole. Even if this happens, the mass of black hole remains unchanged from the mass just "before" the annihilation event.
Is that due to the conservation of energy and mass?
Yes, this is because of (local) conservation of mass/energy.
George Jones said:
No.
What is this antimatter?
For every particle of matter, there is a corresponding particle of antimatter. The (additive) quantum numbers of an anitparticle have values that ere the negatives of the values of the quantum number for the corresponding particle.
For example, an electron has negative electric charge, and a positron (anitmatter electron) has positive electric charge. If a particle and corresponding antiparticle collide, they annihilate each other, releasing energy.
George Jones said:
...For example, an electron has negative electric charge, and a positron (anitmatter electron) has positive electric charge. If a particle and corresponding antiparticle collide, they annihilate each other, releasing energy.
Tangents, if you are inclined:
Assuming the electron and positron are the same thing(? same mass, etc) differing only in charge:
1. Why don't an electron and positron settle into quantum mechanical orbitals about each other similar to the traditional electron and nucleus?
2. If an high energy electron can in fact be made to collide with a (proton based) nucleus, why does it not 'annihilate' some 1/1800 th of the much larger proton?
