Block down ramp colliding with spring
  • Thread starter Thread starter TraceBusta
    Block Ramp Spring
The discussion focuses on calculating the maximum compression of a spring when a block is released from a height on an inclined plane. The initial approach involved using energy conservation equations, equating kinetic energy and potential energy. However, the gravitational potential energy must account for the total distance the block travels, including the compression of the spring. A correct setup involves using the total distance in the gravitational potential energy equation, leading to a quadratic equation for solving maximum compression. The participants emphasize the importance of accurately measuring the gravitational potential energy from the lowest point to find the correct compression value.
TraceBusta
A 3.2-kg block is released 34m from a massless spring with force constant 178N/m that is fixed along a frictionless plane inclined at an angle of 27° above the horizontal. Find the maximum compression of the spring.
This is what I have tried so far.
equation (1) (1/2 mv^2) = (1/2 kx^2)
equation (2) (1/2 mv^2)=d*mg(sin theta)
i used equation (2) to solve for v.
then using that value of v i solved (1)
my answer for x=2.333 meters, however that is wrong
In calculating the gravitational PE, don't forget to include the distance the block falls in compressing the spring a distance X.
ok, i think i understand the concept of that, but I'm not sure how I would set that up in equation form. Because gravity works in the y-component, would i have to use 2 equations. 1 to include for the y-distance the spring compresses and another to solve for the total compression in the sin (theta) component of the spring? If that was the case then I don't know how to set those up because i am trying to solve for maximum compression and in the first equation i woul dneed to know that.
Think of it this way: How far does the block slide? d = 34m + x. (x = how far the spring compresses.) Use energy conservation: Intial energy (gravitational PE) = final energy (spring PE). You'll get a quadratic equation.
Hint: measure gravitational PE from the lowest point.
i set up the problem like this
U=mg(h+x sin (theta))
Uspring=1/2 k x^2
so mg(h+x sin (theta)) = 1/2 kx^2?
solving for x, x1=1.1331, x2=-1.0965
those are both wrong.
Ugrav = mgd sin(theta), where d = 34m +x
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
