Undergrad Blu-Ray Disc: Shorter Wavelength, Bigger Storage?
Blu-ray discs utilize a blue laser with a wavelength of approximately 405nm, compared to the red laser of CDs at 650nm. The shorter wavelength allows for a smaller laser spot size, enabling more data to be recorded on the disc. This is analogous to reducing font size to fit more text on a page. Blu-ray players have specialized electronics and lenses to focus the blue laser, allowing for higher data density and storage capacity compared to CDs and DVDs.
  • Understanding of laser technology and wavelengths
  • Familiarity with data storage concepts
  • Knowledge of optical disc formats (CD, DVD, Blu-ray)
  • Basic electronics related to laser systems
  • Research the differences between CD, DVD, and Blu-ray storage capacities
  • Learn about the physics of laser optics and spot size
  • Explore the technology behind Blu-ray players and their components
  • Investigate advancements in optical disc technology beyond Blu-ray
Engineers, optical media developers, and anyone interested in data storage technologies will benefit from this discussion.
avito009
blu ray disc has a shorter wavelength than a red laser (650nm), but how does having shorter wavelength effect storage space? answer in laypersons terms.
If you imagine the laser beam as a thin cylinder that has a small radius r , then this radius r depends on the wavelength of the laser. The smaller the wavelength the smaller the radius r. And the smaller the radius r is, the smaller is the spot that the beam leaves on the disc when we do recording of data (the laser beam switches between on to record a 1 bit and off to record a 0 bit, actually it is high power/intensity for the 1bit and low power for the 0 bit). The smaller that spot is, this means that the smaller one bit of data is, so we can put more bits on the same disc, so more data.
Likes davenn
So you mean that inside the CD player, there is a miniature laser beam? but if there is a laser beam inside the cd player then is this laser red or blue and how does blu ray have blue laser? So is the laser inside the disc? or is it in the cd player?
So can we use this analogy?
If you've ever had to squeeze a certain amount of text on a single sheet of paper (maybe to make a poster) and found it difficult to get everything on, you'll know there's a simple solution: you just make your words a bit smaller (lower the font size). The same idea works when you're writing computer data on discs with laser beams. You can store more on a DVD than a CD by using a laser beam that "writes smaller". And to read or write a Blu-ray disc, you use a laser to write even smaller still.
I think i know somewhat what happens but correct me if i m wrong. the cd drive shins a laser that is red in color and the blu ray disc reflects a blue laser beam. So originally the cd player shines a red beam of laser but blue beam is reflected from the blu ray disc
The cd player/recorder has electronics and focus lens that produce and focus a red laser beam . The Blue-Ray player/recorder has electronics and lens that produce and focus a blue laser beam. The beam is produced by the player/recorder and when we choose to play the disc, the beam is produced with low power and is reflected by the surface of the disc. When we choose to record the disc, the beam is produced with high power and can "burn" the surface of the disc at tiny spots whose radius depend on the wavelength of the beam, the radius of the spot is smaller for blue beams and larger for red beams.
yes that is exactly the analogy.
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
22K
  • · Replies 20 ·
