davidge said:
Like the theorem that says that ##A \times B## is homeomorphic to ##C## iff both ##A## and ##B## are homeomorphic to ##C##, or like the compactness property
What do you mean? If ##A=B=C=\mathbb{S}^1## is the circle, then ##A \times B = \mathbb{S}^1 \times \mathbb{S}^1## is a torus, which is not homeomorph to a circle ##\mathbb{S}^1## (wrong dimensions). Don't confuse homeomorphisms with homotopy mappings.
Now the problem is that if the circle is'nt homeomorphic to ##\mathbb{R}^2##, then the definition of a boundary on a manifold doesn't seem to work in this case, because that definition says a manifold don't have a boundary if the neighborhood of each of its points is homeomorphic to ##\mathbb{R}^n##. In the case of the circle, we know it does not have a boundary, but yet it's not homeomorphic to ##\mathbb{R}^2##.
It gets automatically confusing here, as terms are used a bit ambiguously when it comes to manifolds compared to ordinary topological spaces. As manifolds are also topological spaces, this is a very unlucky situation, which in my language is solved by an extra name.
Let's see whether I can get it right.
The boundary ##\partial S## of a set ##S## in a topological space ##X## can be defined as ##\partial S = \overline{S} \cap \overline{X - S}##.
As topological space, a manifold is automatically closed as well as open, which makes its boundary automatically empty. This is a direct result of the fact, that the manifold is the entire available space. No embeddings into some outer space!
As an embedded structure, like a ball in usual space, it has the the topology of this outer space and a boundary there: The open ball ##\{(x,y) \in \mathbb{R}^2\,\vert \,x^2+y^2 < 1\}## has the boundary ##\{(x,y) \in \mathbb{R}^2\,\vert \,x^2+y^2 = 1\}##, the sphere, although it doesn't belong to the open ball anymore, or in case of ##\{(x,y) \in \mathbb{R}^2\,\vert \,x^2+y^2 \leq 1\}## it has also the sphere as boundary which this time is part of the set, the closed ball. The space itself, here ##\mathbb{R}^2##, has no boundary.
But as we don't want to have embeddings, when it comes to manifolds, we have to say goodbye to outer spaces.
Instead we have an atlas of our manifold ##M##, which gives us the family of regular charts on open sets. Now to speak of a boundary, we consider the prototype of something with a boundary, namely the set ##\mathbb{R}^n_+ = \{x \in \mathbb{R}^n\,\vert \,x_n \geq 0\}##. Next we allow besides our regular charts, some additional boundary charts for our sets ##U \subseteq M##, that is a chart that is a 1-to-1 map ##\phi## such that ##\phi(U) \subseteq \mathbb{R}^n_+## is open. Regular points are those covered by regular charts, and boundary points are points which are not regular, that means covered by a boundary chart plus the condition ##\phi(p)_n =0##. This way the boundary property of ##\mathbb{R}^n_+## is transported into terms of the manifold via its atlas.
So as for the circle, all remains as it is, i.e. no boundary at all since it has no interior.
However, if you mean the disc ##M=\{(x,y) \in \mathbb{R}^2\,\vert \,x^2+y^2 \leq 1\}## instead, then the circle of this disc is its boundary in the sense that it contains the boundary points (charts which map to ##\mathbb{R}^2_+=\{(x,y)\in \mathbb{R}^2\,\vert \,y\geq 0\}##).
If you take away these points, i.e. ##M=\{(x,y) \in \mathbb{R}^2\,\vert \,x^2+y^2 < 1\}##, then it has no boundary points, as all points are covered by regular charts.
Or should we just use the fact that a manifold is required to be locally Euclidean and conclude that the circle is locally homeomorphic to ##\mathbb{R}^2##?
The circle is a one dimensional curve and as such locally homeomorph to an open interval of the straight line ##\mathbb{R}^1##.
But if we proceeded this way, then we would find that there're no manifolds with boundaries at all and the whole concept of boundary would become meaningless.
No, not really meaningless, just "handle with care". (See above, if I got it right. Pretty late here now.)
One last remark: The charts in an atlas don't have to be global, that is there is usually not a single chart that maps ##M## to ##\mathbb{R}^n##, so there isn't a global homeomorphism needed. We only need local charts like in a real world atlas: pages of open sets which map to open sets in Euclidean space.
