Solving Light Refraction Boundary Conditions: Find T^-1
drcrabs
Can someone please help me with this question:
Light with frequency \omega in media 1 ,with refractive index n_{1} , is incident (normal) to an interface of media 2, with refractive index n_{2}, and then is incident on a second interface with refractive index n_{3}. Using boundary conditions show that the transmission coefficient is:
T^{-1} = \frac{1}{4n_1n_3} ((n_1+n_3)^2 + \frac{(n_1^2-n_2^2)(n_3^2-n_2^2)}{n_2^2} Sin(\frac{n_2d\omega}{c}))
So basically light starts in one media and passes though two different media and we get the above as the transmission coefficient
If I understand correctly, T is what comes out the n2 area, to n3 and infinity?
The point in this question is this:
1. find the genreal Fresnel Coefficients for reflection and transmition between two medias (you can find it around page 306 in Jackson 3re ed.).
2. Now look at your own wave - it is transmitted into n2, some passes into n3 but some reflects from the n2-n3 boundary back to n2, some passes back to n1 and some again is reflected to n3. The wave is reflected an infinite amount of times and there is an infinite sum involved of all the transmitted waves. Luckily, it's a geometric series.
P.S you must assume the media is non-magnetic to get this expression.
3. Don't forget the phase added to the wave while passing n2.
That problem is worked out on page 285 of Franklin "Classical Electromagnetism". The sin should be sin^2.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
