Solve Box Potential Problem: Find Wave Functions & Express in Sine/Cosine
  • Thread starter Thread starter quantum_prince
    Box Potential
quantum_prince
Taking a particle m with box potential (one dimensional) where V(x) = 0 when mod(x) <=a and V(x) = infinity when mod(x) > a and where wave function phi(x) = A (phi1(x) + ph2(x)) where phi1(x) and phi2(x) are normalized wave functions of the ground state and first excited state
We need to Assume that the wave function (x, t) at time t = 0 is given by \psi (x,0) = \phi (x) need to find \psi (x, t) and \psi (x, t)^2 e need to express the latter in terms of sine or cosine functions, eliminating the
exponentials with the help of Euler’s formula.
Abbreviation to be used is:
w = \pi ^2 h/8 m a^2
How do I proceed in this regard.
I know that
ih dow W /dow t = -h^2/2m dow^2/dow x^2 + V(x) psi
Since V(x)=0 that term disappears so we have
ih dow \psi / dow t = -h^2 /2m dow^2/dow x^2
Euler formula.
e^i[\theta] = \cos\theta + i \sin\theta
Regards QP
Do you know how phi1 and phi2 evolve in time? (Hint: They're stationary states, i.e. eigenstates of the Hamiltonian), Once you know that, you can easily write down the evolution of any linear combination of phi1 and phi2 by using the linearity of Hthe Hamiltonian.
Hi Galileo,
This is how I would proceed.I have attempted to find a solution to
the problem.Please guide me if am wrong as you did before.
General solution to Schroedinger equation:
psi(x,t) = phi(x) exp(-i(n+1/2)wt)
Now using phi(x) given in our problem
pxi(x,t) = A(ph1(x) + ph2(x)) exp(-i(n+1/2)wt)
since w = pi^2h/8ma^2
phi(x,t) = A(phi1(x) + phi2(x)) exp(-i(n+1/2)pi^2/8ma^2*t)
Z = (n+1/2)pi^2/8ma^2*t
phi(x,t) = A (ph1(x) + phi2(x)) (cos Z - i sinZ)
Regards.
QP.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
