Brachistochrone with velocity - still a cycloid
The Brachistochrone problem demonstrates that even with an initial velocity \( v_0 \neq 0 \), the path of minimum time remains a cycloid. The conservation of energy equation, \( \frac{1}{2}mv^2 - mgy = \frac{1}{2}mv_0^2 \), is fundamental in deriving the differential equation \( \frac{dy}{dx} = \sqrt{\frac{k^2 - v_0^2 - 2gy}{v_0^2 + 2gy}} \). The discussion emphasizes the transformation of the initial velocity into a vertical change in height, leading to the simplified differential equation that confirms the cycloidal path. The solution process involves recognizing the relationship between height and velocity in the context of the cycloid.
  • Understanding of the Brachistochrone problem
  • Familiarity with differential equations
  • Knowledge of conservation of energy principles
  • Basic concepts of cycloids in physics and mathematics
  • Study the derivation of the cycloid path in the Brachistochrone problem
  • Learn techniques for solving differential equations related to motion
  • Explore the implications of initial velocity on trajectory in physics
  • Investigate applications of cycloids in real-world scenarios, such as roller coasters
Students of physics and mathematics, particularly those studying classical mechanics, as well as educators and anyone interested in optimization problems involving motion and trajectories.
Grand
Brachistochrone problem: if the particle is given an initial velocity v_0 \neq 0[\tex] , show that the path of minimum time is still a cycloid.<br /> <br /> <h2>Homework Equations</h2><br /> Conservation of energy:<br /> \frac{1}{2}mv^2-mgy=\frac{1}{2}mv_0^2[\tex]&lt;br /&gt; &lt;br /&gt; &lt;h2&gt;The Attempt at a Solution&lt;/h2&gt;&lt;br /&gt; I know how to start the problem, but in the end have to solve the differential equation:&lt;br /&gt; \frac{dy}{dx}=\sqrt{\frac{k^2-v_0^2-2gy}{v_0^2+2gy}}[\tex]&amp;lt;br /&amp;gt; which I can&amp;amp;#039;t solve. Any ideas and hints would be greatly appreciated!
Anyone with a decent solution?
Grand said:
Brachistochrone problem: if the particle is given an initial velocity v_0 \neq 0 , show that the path of minimum time is still a cycloid.
which I can't solve. Any ideas and hints would be greatly appreciated!
You have to put at forward slash to close a latex instruction ie: /tex
Think of the initial velocity as the result of a vertical change in position of a height y0 along this path from a starting point of 0. Then you just have:
\frac{dy}{dx}=\sqrt{\frac{k^2-2gy0-2gy}{2gy0+2gy}}
which reduces to:
\frac{dy}{dx}=\sqrt{\frac{k^2-2g(y0+y)}{2g(y0+y)}}
\frac{dy}{dx}=\sqrt{\frac{k^2-2gy&#039;}{2gy&#039;}}
the solution to which is a cycloid.
AM
  • · Replies 21 ·
