How Do You Calculate the Lattice Constant Using Bragg's Law?
  • Context: Undergrad
  • Thread starter Thread starter vebbie
    Constant Lattice Law
The calculation of the lattice constant using Bragg's Law involves substituting specific values into the equation nλ = d sin θ. In this discussion, a simple cubic lattice is analyzed with an X-ray wavelength of 1.6 Å, focusing on the (222) peak at an angle of 32 degrees. The diffraction order, n, is set to 1 for the first-order diffraction lobe. The spacing, d, corresponds to the (222) planes, and higher-order peaks, such as (422), do not affect the calculation as they require a Laue pattern for observation.
  • Understanding of Bragg's Law and its application in X-ray diffraction.
  • Knowledge of lattice structures, specifically simple cubic lattices.
  • Familiarity with the concept of diffraction orders in crystallography.
  • Basic geometry skills to interpret diffraction data.
  • Study the derivation and applications of Bragg's Law in crystallography.
  • Learn how to calculate interplanar spacing for different Miller indices.
  • Explore the generation and interpretation of Laue patterns in X-ray diffraction.
  • Investigate the differences between forward and backward scattering in diffraction experiments.
Students and researchers in materials science, physicists working with crystallography, and anyone involved in X-ray diffraction analysis of crystalline materials.
vebbie
need help working out this problem. if you have a simple cubic lattice characterised using x-ray diffraction with a wavelegth of 1.6\dot{A}. The main peak in the scan is (222) and the angle is 32 degrees. By using braggs law to find the lattice constant do you just sub in the values and solve for d? (n\lambda=dSin\theta. If so what value do you use for "n".
It is the diffraction order, use 1 for the first order diffraction lobe.
but does the peak have any use for the calculation. suppos it was the 422 peak
d is the spacing of the (222) planes. If you were looking at the (422) reflection, then d would be the spacing of the (422) planes. You might have to do some geometry to get the lattice spacing from the data.
"but does the peak have any use for the calculation. suppos it was the 422 peak"
The index n is a consequence of the fact that reflections occur when (k - k') = G. Braggs Law diffraction condition is a simplification of the Laue Condition for diffraction: (k - k') = G. The higher order peaks are forward scattering instead of backwards scattering so you won't be able to see them in a standard diffractometer. You would nee to generate a Laue pattern to see these peaks. To answer your question you don't need these peaks.
modey3
  • · Replies 54 ·
10K
