Is Bragg's Law Equation Modified for Different Incidence Angles?
  • Context: Graduate
  • Thread starter Thread starter helloween0908
    Bragg's law Law
The discussion clarifies the modification of Bragg's Law for different incidence angles, specifically when light strikes a diffraction grating at an angle θ’ rather than the typical θ. The correct condition for intensity maxima is expressed as d(sin θ + sin θ’) = mλ, where m represents the order of diffraction (m=0, ±1, ±2, ±3...). This adjustment accounts for the path differences between incident rays and those diffracted by the grating. The conversation emphasizes the distinction between x-ray diffraction and optical diffraction grating applications.
  • Understanding of Bragg's Law in the context of x-ray diffraction.
  • Familiarity with the principles of optical diffraction and diffraction gratings.
  • Knowledge of trigonometric functions, specifically sine and cosine.
  • Basic grasp of wave interference and path difference concepts.
  • Study the derivation of Bragg's Law for x-ray diffraction in detail.
  • Explore the mathematical principles behind diffraction gratings and their applications.
  • Learn about the differences between optical and x-ray diffraction techniques.
  • Investigate the role of path difference in wave interference phenomena.
Students and professionals in physics, particularly those focusing on optics and crystallography, as well as researchers working with diffraction phenomena in various materials.
helloween0908
problem: In Bragg's law equation, mormally, we measure the angle θ from the surface If instead the light strikes the grating at an angle of incident θ’ (measured from the normal), show that the condition for an intensity maximum is not 2dsin θ= mλ (m=1,2,3...)
but rather
d(sin θ + sin θ’ ) = mλ (m=0, ±1, ±2, ±3...)
No matter which way I tried, I finally ended up with 2dcosθ’ rather than d(sin θ + sin θ’ ) = mλ (m=0, ±1, ±2, ±3...).
Can anyone help me?
When you say "Bragg's law" usually you mean x-ray diffraction on a lattice.
Here it seems that you have something else: diffraction of light from a diffraction grating.
Or maybe a mix-up.
The formula with the sum of the two sines applies to the diffraction grating when the light hits it at an angle theta'.
There is a path difference between the incident rays hitting two different "holes" in the grating and this is given by d*sin(theta'). And then there is the path difference between the rays on the other side of the grating which is d*sin(theta).
I hope this helps.
Is this what you mean:
The Bragg's law becomes:
the length of the red+ blue lines = d(sin θ + sin θ’ ) = mλ
No. As I said, I was referring to an optical diffraction grating.
something like this:
http://en.wikipedia.org/wiki/Diffraction_grating
The math is similar though.
For x-ray diffraction from the crystal the maximum occurs when the two angles are equal.
oh, thanks.
The problem seems clear now :D
