Breakdown Voltage of PN Junctions: P+-N vs. N+-P
  • Thread starter Thread starter Fermi_98
    Voltage
The discussion focuses on the breakdown voltage of p+-n and n+-p diodes, with an emphasis on understanding which configuration has a higher breakdown voltage under identical design parameters. Clarification is provided on the notation used, indicating that p+ and n+ denote high doping concentrations in p-type and n-type semiconductors, respectively. The breakdown voltage is influenced by the doping levels and the junction's electric field strength. The conversation highlights the importance of understanding these parameters in the context of high voltage rectifiers. Ultimately, the breakdown voltage characteristics of these diodes are crucial for their application in power electronics.
Fermi_98
Hiya,
Being a computer science and eng first year student, just trying to understand one artical regarding Breakdown voltage of a pn junction.Could anybody explain me, which diode out of the following have higher breakdown voltage if they have same design parameters such as doping and thickness and why ?
1. p+-n diode
2. n+-p diode
Fermi_98 said:
Hiya,
1. p+-n diode
2. n+-p diode
Can you clarify your diode notation. It seems ambiguous.
Chris
I suppose, i should have rather written as p+nn+. If you are familiar with power rectifiers, it is quite common notation used in there, to denote the high voltage rectifier.
High voltage rectifiers are fabricated in silicon which is either n-type or p-type.
1. "p" refers to quantity of the p-type semiconductor for instance boron etc. The + sign shows that boron atoms concentration, we are talking is in the order of greater then 1e18 cm-3 .This much of the boron atom concentration is diffused into the n type silicon to make a rectifier. It is therefore denoted by p+n.
2. like wise "n " refers to n-type semiconductor for instance phosphorous etc. Again, when the doping concentration is very high, we denote it by n+.
so same is applicable to other type of the rectifier for instance n+pp+.
