Understanding Discrete Symmetries in Quantum Field Theory
ismaili
I don't quite understand the treatment of discrete symmetries, for example, in Peskin's QFT book:
Because by definition time reversal symmetry should flip the spin and momentum, so he defined an operation to flip the spin state of a two-component spinor, i.e.
\xi^{-s} \equiv -i\sigma^2(\xi^s)^* \quad\cdots(1)
, from this definition of spin flip, we have \xi^{-s} = (\xi^2 , -\xi^1).
And, previously, he has already solved the Dirac equation and got solutions:
u^s(p) = (\sqrt{p\cdot\sigma}\xi^s , \sqrt{p\cdot\bar{\sigma}} \xi^s)
v^s(p) = (\sqrt{p\cdot\sigma}\eta^s , -\sqrt{p\cdot\bar{\sigma}} \eta^s)
where \xi^s, \eta^s are two-component spinor basis.
Now he chooses
v^s(p) = (\sqrt{p\cdot\sigma}\xi^{-s} , -\sqrt{p\cdot\bar{\sigma}} \xi^{-s})
and he defines
a^{-s}_{\mathbf{p}} = (a^s_{\mathbf{p}} , -a_{\mathbf{p}}^1) , b^{-s}_{\mathbf{p}} = (b^s_{\mathbf{p}} , -b_{\mathbf{p}}^1)
Then, he can compute T\psi T = \cdots = \gamma^1\gamma^3 \psi(-t,\mathbf{x})
My questions:
(1) Why he defined the spin flip by eq(1)? and why does he define a_{\mathbf{p}}^{-s} in such a way? Why doesn't he just define \xi^{-s} = (\xi^2 , \xi^1)?
(2) He worked out all these discrete symmetric transformation of spinor fields in a particular representation of gamma matrices, i.e. chiral representation of gamma matrices. Is it possible to deal with discrete symmetries without working in a particular representation? Is the result he gets representation independent?
(3) Is it possible to define discrete symmetries in other dimensions? They can be defined only in certain dimensions or in arbitrary dimensions?
Thank you so much.
Now he chooses
and he defines
My questions:
Thank you so much.
(1) I still don't know the solution to question (1). I found that for a two-component Weyl spinor, -i\sigma^2 (xi) is actually the definition of charge conjugation. But he called such a transformation as spin flip.
When we solve the Dirac equation, u(p) = \sqrt{m}(\xi^s,\xi^s)^T and v(p) = \sqrt{m}(\eta^s,-\eta^s)^T, where \xi^s, s=1,2 are two independent basis of two-component spinors, and \eta^s, s=1,2 are another two independent basis of two-component Weyl spinors. Peskin chose \eta to be the charge conjugate of \xi. In this way, the relation u^s(p) = -i\gamma^2(v^s(p))^* is only valid when we made such a choice?
(2) The relation among gamma matrices was found once, it is valid in any representation. So, to this question, the answer should be yes. The result we get is of course representation independent.
(3) still need study..
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
