C plus and ACAUSALITY in accelerating systems
  • Level: Graduate
  • Thread starter Thread starter Austin0
    Accelerating Systems
5 replies · 2K views · last reply
Austin0
Hi I just encountered a couple of concepts I was unaware of in another thread.
As the thread was an intence discussion on another topic I am posting this here.
The speed of light is not limited to c wrt an accelerating (or rotating) reference frame. It can have any value up to infinity.
But we do have to acknowledge that accelerated reference frames are fundamentally different from inertial frames: not only can distant objects exceed c, change velocity with no force applied, etc., but causality itself can be violated, ie effect can precede cause.
So any insights or references regarding this would be appreciated.
Explanations , interpretations or comments.
Thanks
In accelerating frames, a preceding event may be assigned an earlier time coordinate than the following event. That does not violate causality, it just reminds us that in GR coordinates can be chosen as convenient, and don't have the intrinsic physical meaning as in SR.
Classically speaking, the only way to measure the speed of an object, is to measure the time it takes for that object to travel from one position to another. This is unfortunate because all kinds of fun things can happen between those two measurements (the object might accelerate, our own ref frame might accelerate). So then let's think about a speed measuring device that uses an infinitesimal period of time to measure the speed of an object. Will that solve our problem? No, because we can also imagine astronomical acceleration rates. An infinitesimal speed-measuring time for an astronomically-accelerating object still might give us incorrect data. Additionally, the gravitational potential might be different at the two places we measure. If anything, its just a practical issue. There is no speed faster than light and the statement about causality being "violated" is simply wrong.
Glad to hear it.
But you seem to be considering Gr spacetime and a system accelerating through spatial motion as, not just equivalent, but synonymous.
I am not arguing with that viewpoint but in this case the writer seemed to be referring to moving frames.
That is why I was perplexed. AS far as my knowledge goes, relative motion [of any kind ]can produce reordering of separated events but never if there is a causal link or if they occur in the same location.
Although preceding events can be assigned an earlier time coordinate than following events.. Thanks
Oops. Yeah, GR is really strange. :redface:
Thanks
I'll comment since I think I was the author of that quote. I shouldn't have said "causality can be violated", since the rule that cause must precede effect is only valid in inertial coordinate systems.
Effect can precede cause in a non-inertial coordinate system, but only at a distance beyond the horizon of the accelerated observer. It's just a result of subtracting the light travel time from the detection of the events. The detection of the cause always precedes the detection of the effect, but if the coordinate distance of the events increases drastically between the detections due to reduced relative velocity, the "light delay corrected" time of the effect may be prior to the cause.
