Alternatives for Cabling Support in 40 Floor Projects
  • Thread starter Thread starter eduardotobon
    Projects Support
The discussion focuses on alternatives for supporting electrical cables in high-rise buildings exceeding 40 floors. The designer initially recommends using OZ / GEDNEY type S cable clamps with pozi-grip, which are noted to be costly. Participants suggest considering Hubbell-Kelems support grips as a more economical option, especially if the installation allows for interruptions in the PVC conduit every 60 feet, as per NEC Table 300.19(A). Additionally, the use of covered cable trays is recommended for effective cable management.
  • Understanding of NEC (National Electrical Code) regulations
  • Familiarity with PVC conduit installation standards
  • Knowledge of electrical cable types, specifically THHN 3/0
  • Experience with cable support systems, including cable clamps and grips
  • Research Hubbell-Kelems strain relief grips for cable support
  • Study NEC Table 300.19(A) for conduit support requirements
  • Explore the use of covered cable trays for high-rise installations
  • Investigate alternative cable clamp options to OZ / GEDNEY products
Electrical engineers, project managers in construction, and contractors involved in high-rise building projects seeking cost-effective cable support solutions.
eduardotobon
I have a project of more than 40 floors in height, in which the cables go from ground floor to each of the floors (1 tube 2-1/2" PVC + 4 conductors THHN 3/0 + ground in the higher floors ) The designer recommends the use of OZ / GEDNEY type S cable clamps with pozi-grip These supports are very expensive and I want to know what alternatives are there to support the cables since the path is long.
Welcome to the PF.
What country is this for? What electrical codes apply to these wire runs? Is it allowed to use non-conducting PVC tubing for wire runs in commercial buildings where you are?
If you may interrupt-and terminate- the pvc conduit all 60 ft [see NEC Table 300.19(A)]-4 floors about-you may use usual support grips -Hubbel-Kelems-for instance. A box or a piece of covered cable tray is to be provided in this place. See-for instance :
http://www.graybar.com/manufacturers/hubbell/wdk/kellems-strain-relief-grips
11K
  • · Replies 38 ·
10K
9K
  • · Replies 19 ·
  • · Replies 23 ·
