Calc 2 Differentials: Carbon Dioxide in Room of 180 m^3
The discussion focuses on calculating the percentage of carbon dioxide in a room with a volume of 180 m³, initially containing 0.20% CO2. Fresh air with 0.05% CO2 enters the room at a rate of 3 m³/min, while mixed air exits at the same rate. The user attempts to derive a function for CO2 concentration over time but receives feedback indicating that their initial formula is incorrect, particularly because it does not satisfy the initial condition of 36 grams of CO2 when t=0. The conversation highlights the need for a correct approach to modeling the differential equation governing the situation. Accurate calculations are essential for determining the CO2 concentration as a function of time.
tnutty
The air in a room with volume 180 m^3 contains 0.20% carbon dioxide initially. Fresher air with only 0.05% carbon dioxide flows into the room at a rate of 3 m^3/min and the mixed air flows out at the same rate.
(a) Find the percentage of carbon dioxide in the room as a function of time.
attempt :
dy/dx = rate in - rate out
rate in = 0.05 * 3
rate out = 3 * y/180
from that my answer turned out to be :
y(t) = - (e^ (-t/60) * e ^(ln(9) + 1/300 ) - 9 )
any help?
What help are you asking for? If you want to know if that is the correct answer, no, it is not. For one thing, when t= 0, y should be 0.2(180)= 36 but your formula gives y(0)= eln(9)+ 1/300- 9. If you want to know what you did wrong, we will have to see what you did first!
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
11K
