Calc moment of a hydraulic piston?
The discussion revolves around a homework problem involving the calculation of forces and moments related to a hydraulic piston acting on a ladder. Participants are exploring concepts of static equilibrium, force components, and moments in the context of engineering statics.
  • Homework-related
  • The original poster describes the problem setup, including the forces acting on the ladder and the geometry involved, but expresses uncertainty about calculating the moment at point C and the weight of the ladder.
  • One participant requests a diagram and suggests labeling points to clarify the geometry, indicating a need for clearer boundary conditions and support reactions.
  • The original poster shares an image of the ladder problem and another problem, indicating confusion about the concept of moments and expressing a desire to improve understanding.
  • Another participant asks for a definition of "bending moment at a section," indicating a need for conceptual clarity on this term.
  • A participant comments on the forces at point C, suggesting that the pole is compressing and provides a guess for the components of forces at point B, indicating uncertainty in the calculations.
  • One participant emphasizes the importance of drawing a free-body diagram for solving forces and moments, suggesting that the original poster should analyze the structure using equilibrium equations.
Participants express varying degrees of understanding regarding the calculation of moments and forces, with some suggesting methods to clarify the problem while others indicate confusion. There is no consensus on the correct approach or solution to the problem.
Participants highlight the need for free-body diagrams and equilibrium equations, suggesting that the original poster may be missing key concepts in their approach to the problem. Specific assumptions about the geometry and forces are not fully defined, leading to ambiguity in the discussion.
sf2k
Working through 5.17 problem in Bedford 5th edition (Engineering Statics) p214
"The hydraulic piston AB exerts a 2000 N force on the ladder at B in the direction parallel to the piston. Determine the weight of the ladder and the reactions at C."
piston between A and B on an angle theta.
point C is further away from A and B by 1 metre along the base.
1m height from A->B or C->B
2m distance between base A->B
1m distance between base B->C
2m distance between the centre Weight of the ladder and the end point C
Tan -1(opp/adj) gives the angle of force for C(x) and C(y).
forces on the x plane are cos theta
forces on the y plane are sin theta
F = ma using 9.81 m/s^2
Sum of F(x) = C(x) + (2000/9.81) cos theta = 0
since base between A and B is 2 and height is 1 thus tan -1 (1/2) = 26.57 degrees
Sum of F(x) = C(x) + 203.87 cos 26.57 = 0
C(x) + 182.34 = 0
C(x) = -182.34 kgSum of F(y) = C(y) + 203.87 sin 26.57 - W = 0
The W force counters the C(y) force so I subtracted.
Don't know how to calculate C(y).
Sum of M(c) = ??
not sure how to calculate the moment at C nor solve for W.So I"m missing concepts from class in terms of when to solve for what and why. I have seen the answers for it so it's not a question of getting an answer. But I'm not following what to do for myself and I want to understand what is going on, what the moment is at C, and how to calculate it out.
Thanks for any advice or attempts at improving my understanding.
sf2k: Can you post a diagram, or give the (x, y) coordinates of each point? Make up a letter for all points that do not already have a label. Let's call the centroid of the ladder point D, and the lower end of the ladder point E (?). E.g., if point B is arbitrarily chosen as the origin, let me see if I understand your diagram. In units of metres, the coordinates would be B(0, 0), C(1, 1), A(-2, -1), D(-1, -1)? But what are the coordinates of point E? And what is touching points A, C, and E? I.e., what are the boundary conditions, meaning what are the supports around your structure, which apply the reaction forces?
Here's the ladder problem with image attached. Also another problem with just image. (Solve for moment at B). Oddly the ladder prob is more complex but the second problem shows I don't really know the process.
I don't know what is is about Moment that I keep forgetting. I think we can flush it out though between these two examples and figure our where the holes are in my understanding. This could then help others in similar straits.
For your second problem, could you define what you think the "bending moment at a section" is?
Not sure. It's confusing since it looks like at C the pole is compressing upwards and outwards since the force it at an angle upwards at 40N and outwards at 48N. So I'll guess the component at B(y) of (1.2)(40)sin45 up and B(x) of 48N to match C(x).
sf2k: For your second problem, your answer for Bx is correct. Your answer for By is currently incorrect. One thing that appears to be missing is a free-body diagram. You posted a diagram of the given structure; but any time you need to solve for forces and moments at a support or at an internal section cut, you must draw a free-body diagram, which means you must draw the unknown reaction forces, or unknown forces and moments at the section cut. Then you use equilibrium equations to solve for the unknown forces and moments.
E.g., make a section cut at point B, and analyze only member BC. At the section cut, draw the unknown forces and moment acting on the section cut. Go ahead and do it. After you draw it, write the equilibrium equations only for the sectioned-off structure, member BC. Now solve the equilibrium equations, and it will give you the forces and moment at the section cut at point B. Use the right-hand rule for moments, and say anticlockwise moments are positive. Show your work, and someone can check your math. Also, see the last paragraph of post https://www.physicsforums.com/showpost.php?p=2946515".
  • · Replies 27 ·
  • · Replies 19 ·
