Calc Problem: Find Angle of Intersection Between r1(t) & r2(t) at Origin
  • Thread starter Thread starter Juntao
The curves r1(t) and r2(t) intersect at the origin, and the goal is to find the acute angle of intersection. The derivatives of the curves at the intersection point are calculated as r1'(0) = <1, 0, 0> and r2'(0) = <1, 2, 1>. The angle between the two vectors is determined using the dot product formula, leading to an angle of approximately 66 degrees. There is some confusion regarding the interpretation of hints provided in the problem, particularly about whether to use tangent lines. Ultimately, the calculations align, confirming the angle found.
Juntao
The curves r1(t)=<t,t^2,t^3> and r2(t)=<sin t, sin 2t, t> intersect at the origin. Find their angle (acute) of interesection correct to the nearest degree. (Think! What angle are you trying to locate? Now dn't go off on a tangent.)
So that's the problem.
All I got so far is
r1(t)=t(i)+t^2(j)+t^3(k)
r2(t)=sint(i)+sin 2t(j)+t(k)
Now I'm stuck. I'm not sure where to go now.
They intersect at the origin at t=0. Now, I only know how to find the angle between two straight lines, so I would disregard the hint and take the derivative. You get r1'(t)=<1,2t,3t^2>=<1,0,0> and r2'(t)=<cost,2cos2t,1>=<1,2,1>.
Now how do you find the angle f between two vectors?
A*B=ABcosf
1=(1)sqrt(6)cosf
f=arccos(sqrt(6)/6)=66 degrees
How is that "disregarding" the hint? The purpose of the hint was to direct you to the tangent lines of the curves.
I interpreted, "Don't go off on a tangent" to mean "Tangents aren't the way to solve the problem."
Great. My answer matched yours.
  • · Replies 28 ·
  • · Replies 25 ·
