Calculate 0.98M CaCl2 to 0.23M Cl- Solution (mL)
  • Thread starter Thread starter iconwin
To prepare 341 mL of a 0.23 M chloride ion solution, one must first calculate the moles of chloride ions produced from calcium chloride. The calculation shows that 0.078 moles of chloride ions are needed. Using the stoichiometry of the reaction, 40.0 mL of 0.98 M calcium chloride is required for the dilution. The approach taken is confirmed as correct by other participants in the discussion. The user also acknowledges a potential posting error and expresses intent to follow forum regulations in the future.
iconwin
Calculate the following quantity:
Volume of 0.98 M calcium chloride (mL) that must be diluted with water to prepare 341 mL of a 0.23 M chloride ion solution.
You have to try first.
If I understand the problem correctly, I should find how many mol of chloride ions is produced by one mol of calcium chloride first. DO you think that is right?
That's possible approach. For sure you have to do it at some stage.
This is how i worked it out:
CaCl2 + 2H2O => Ca(OH)2 + 2HCl
Mol of Cl:
341mL * (1L/1000mL) * 0.23 mol/L= 0.078 mol of Cl
Vol. of CaCl2:
0.078 mol Cl * (1mol CaCl2/2mol Cl) * (1L/0.98 mol CaCl2) * (1000mL/1L) = 40.0 mL CaCl2
I TRIED HARD ON THIS... IS THIS THE RIGHT ANNSWER!
Looks OK.
Really!? Thanks.
By the way. I think I post this in the wrong section. If you can, please move this post to the proper section. I will read the regulations and follow them the next times.
