Calculate Area Difference of Triangles ABC with AB=5cm, AC=3.2cm
The discussion revolves around calculating the area difference between two triangles ABC, given sides AB=5cm, AC=3.2cm, and angle ABC=35 degrees. Participants clarify that the triangles can be different due to the placement of point C, which can create two distinct triangles with the same base and angle but different areas. The sine rule and area formula are suggested as methods to solve the problem, but confusion arises over the interpretation of the triangle configurations. One user emphasizes the importance of drawing the triangles to visualize the problem better. Ultimately, the conversation highlights the need for clarity in understanding triangle properties and the correct application of geometric principles.
seboastien
soine cosine rule
I have a question for you, I came across this question while revising for my exam on monday if anyone can answer this I'll be very impressed.
Two different trangles ABC have AB=5cm, AC=3.2cm and angle ABC=35degrees
calculate the difference between their areas.
Welcome to the PF, seboastien. I've moved your post from the General Math forum to the Homework Help forums. An important rule here is that homework/coursework (/revising/studying) questions must be posted here in Homework Help.
Also, we do not give out answers to these types of questions. We do provide tutorial help, to help you to figure out the problem on your own. We need to see some of your own work, though, before we can help you.
So, what are your ideas on how to approach this geometry problem? Why would the two triangles have different areas if they have two equal sides and an equal inclusive angle?
Which is the OTHER triangle? You want just the difference between a triangle and itself?
who said that the sides were the same length? AB=5 and AC=3.2, who said they were the same?
and to symbolipoint, that is the whole question which is why it makes no sense
It sounds to us like you are saying that both triangles have AB=5, and both have AC=3.2, and both have the same inclusive angle. That sounds like the triangles are equal. What are we missing?
the angle of BAC and the side BC, are saying that they are describing two seprate triangles?
What is the original question?
two different triangles ABC have AB=5cm AC=3.2cm and angle ABC=35 degrees
calculate the difference between the two sides
it still doesn't make any sense, if the triangles are seprate then their area is exactly the same surely, using the sine rule you can find the angle C, then you could find A as you know the two other angles meaning there's only one possible answer for the area
Angle ABC isn't the inclusive angle. Given the two sides you are given and the angle you are given, how many possible triangles are there? Can you draw it or them? Hint: Try both obtuse and acute triangles. Then, ask yourself what information you would need to find the area of each.
Draw the segment AB. Now though point B draw a line that makes an angle of 35 degrees to the segment. The only requirement for point C is that it lies on the line and is 3.2cm from point A. So make a circle around point A of radius 3.2cm. The circle hits the line in two points, see?
Hi seboastien...It does make sense if the angle is at B
Draw a line AB of length 5cm, then from point A construct a circle of radius 3.2cm, Then draw a line from B inclined at 35degs from AB and see what you get.
Sorry Dick/Tedjn...didn't see your reply as I posted this
what do you mean inclusive angle
i understand what your saying but i still appear to be getting the wrong answer
according to the textbook te answer is 4.07 cm sqrd but I'm getting 2.somthing
two different triangles ABC where AB=5cm, AC=3.2cm, and angle ABC is 35 degrees, calculate the difference between the two areas
SinA/a=SinB/b
Area=0.5abSinC
drawn line AB then a line at B 35 degrees to AB. then drawn a circle of centre A with a radius 3.2cm, I now have two triangles, one with both sides 3.2cm and the angle between 81.4
the other triangle with sides 1.8cm and 5.5cm and the angle between being 35
using Area=0.5abSinC I have found areas of both triangles and then I have found the difference between them, and I am getting the wrong answer
How can anyone tell unless you post your incorrect solution?
if you read my new "thread" as it were you will find my working
it's half ten in the evenong here, and I should probably get some kip. thanks anyway
I'm not finding any 81.4 angles. I would suggest you drop a perpendicular from A to the line BC and find it's length. Then you can just work with right triangles. Makes things easier for me, anyway. BTW the difference area you want to find is just the area of the isosceles triangle, isn't it? You don't really have to do two triangles.
Multiple-posting of the same question is not allowed here on the PF. I've merged that "new" thread back into this one. Confine your questions about this problem to this thread.
"Isosceles Triangle" -- the two triangles idea is much more sensible than I thought. Point C for ABC can be in either of two places, forming two different triangles. Tricky unless one actually draws the figure and thinks.
