Calculate Bandwidth of Filtered Signal
  • Thread starter Thread starter marina87
    Bandwidth
The discussion revolves around calculating the bandwidth of a filtered signal derived from a bipolar pulse represented as a Fourier series. Participants explore the implications of passing this signal through an ideal low pass filter with a cutoff frequency of 4 kHz and the subsequent steps needed for modulation and frequency analysis.
  • Homework-related
  • One participant questions whether to apply the Fourier Transform to the Fourier Series, given the different domains of the signal and filter.
  • Another participant notes that the Fourier Series provides the frequency spectrum and suggests that the baseband bandwidth can be determined if the fundamental frequency, f0, is known.
  • There is a proposal that if f0 is 1 kHz, the bandwidth would be 3 kHz, but this is contingent on the value of f0.
  • Some participants discuss the nature of the filtered signal, debating whether it remains a Fourier series after filtering.
  • There is mention of using the properties of the Fourier Transform to analyze the modulated signal after filtering, specifically referencing the frequency shift property.
  • Participants consider the implications of multiplying the filtered signal by a carrier signal for DSB-SC modulation and the subsequent analysis of the frequency spectrum.
Participants express uncertainty about the application of the Fourier Transform to the Fourier Series and whether the filtered signal retains its original characteristics. There is no consensus on the best approach to analyze the modulated signal.
Participants highlight the need for clarity on the fundamental frequency f0 and its impact on bandwidth calculations. There are unresolved questions regarding the transition from the Fourier Series to the Fourier Transform in the context of filtering and modulation.
marina87
My message signal is the Fourier Series (x(t)) of a bipolar pulse. This signal passes through the ideal low pass filter, h(f), which has a cutoff frequency of 4Khz. What the baseband bandwidth of the filtered signal?
ƩAn*cos(2*pi*n*f0*t), An= [4*(-1)^((n-1)/2)]/(pi*n)
In other words: x(t)=(4/pi)*[cos(2*pi*f0*t)-(1/3)*cos(2*pi*3*f0*t)+(1/5)*cos(2*pi*5*f0*t)]
I don't know if I should apply the Fourier Transform to the Fourier Series because this one is x(t) and my filter is h(f). What should I do?
marina87 said:
x(t) is my message signal and its a Fourier series. This signal passes through an ideal low pass filter, h(f), which has a cutoff frequency of 4Khz. What the baseband bandwidth of the filtered signal?
Its in the attachment that is in
https://www.physicsforums.com/showthread.php?p=3978590#post3978590
I have no idea how to work a Fourier series x(t) because I feel I am in the time domain and my filter is in the frequency domain. Should I apply the Fourier Transform to the Fourier Series?
Welcome to PF, marina87! :smile:
Your Fourier Series gives you the frequency spectrum.
For instance at ##f_0## the amplitude is ##{4 \over \pi}##, and at ##3f_0## the amplitude is ##{4 \over \pi}{1 \over 3}##.
If you apply a low pass filter, all the higher frequencies are cut off.
To find the baseband bandwidth, you need to know what ##f_0## is.
Do you?
Do you?
I see so if my f0 is 1KHz then my bandwidth will be 3KHz.
But if I modulate this signal with a carrier signal cos(2*pi*fc*t) I still need to use the Fourier Transform , right? In other words I still need to apply the Fourier Transform to the series or wait because I filtered the signal is not a Fourier series anymore? Am I correct?
So what is the highest frequency represented in your Fourier series that is less than your cut-off frequency of 4 kHz?
Yep. :)
There's no real need to apply a Fourier transform.
You can read off the frequency spectrum straight from the Fourier series.
But if you would apply a Fourier transform to you Fourier series, you'll find a transform that shows you spikes at exactly the aforementioned frequencies.Btw, the filtered series is still a Fourier series.
It's just that the higher order terms all have amplitude zero.
3Khz but can you help me with my new analysis. I just need someone to tell me if I am in the right track.
After filtered this signal its not a Fourier Series anymore is just a "regular signal that add to cosines functions. Then I can apply the Fourier Transform right?
I like Serena said:
Yep. :)
Sorry I am confusing you. Let me explain a little more the problem.
First I have to filter my signal x(t) (The Fourier Series) with and ideal low pass filter which has a cut off frequency 4KHz. Afther that this "new signal x1(t)" is multiply by a cos(wct) to obtain a DSB-SC modulation. I am thinking apply the Fourier transform to the modulated signal to obtain the AM expression.
Hmm, the new signal x1(t) is just the sum of 2 cosine terms.
You can simply multiply them by your new cosine term, yielding your DSB-SC modulation.
If you want to find the frequency spectrum, the easiest way is to replace the cosine products by cosine sums, using the relevant goniometric identity.
See for instance the section "Product-to-sum and sum-to-product identities" in http://en.wikipedia.org/wiki/List_of_trigonometric_identities
That is what I was thinking but ones I have the product of the cosines then I can use the properties of the Fourier Transform to obtain the spectrum?
Which properties are you thinking of?
x(t)*cos(2pif0t) ----> 0.5*(X(f+f0)+X(f-f0))
If you use the Eulers formula of a cos(x)= 0.5*(e^(jx) + e^(-jx)) and then multiply by a a function x(t) then you can apply the Frequency Shift property
Yes, that looks usable.
You do realize that:
$$\cos \theta \cos \varphi = {\cos(\theta - \varphi) + \cos(\theta + \varphi) \over 2}$$
Note that this looks a lot like your property.
Thanks for the help.
