Calculate E - capacitor question
  • Thread starter Thread starter blueyellow
    Capacitor
The discussion centers on calculating the electric field (E) and electric displacement field (D) in a parallel plate capacitor filled with two glued dielectric materials. The capacitor has square plates with a distance d between them, much smaller than the plate side length L. The dielectrics have different constants and dimensions, affecting the electric fields in the regions they occupy, as well as in the vacuum between them. The user expresses frustration with their attempts to apply relevant equations, such as E=q/(epsilon0*A) and E=deltaV/d, indicating difficulty in progressing toward a solution. The conversation highlights the complexities of integrating the effects of multiple dielectrics in capacitor calculations.
blueyellow
Consider a parallel plate capacitor with square plates of side L and distance d<<L apart. The bottom plate lies on the x-y plane, and the distance d is parallel to z. A block of dieletric material can completely fill the space between the plates.
Consider the dieletric to be composed of two materials glued together, material 1 with dieletric constant epsilon1 and dimensions 0.6L*L*d (in x, y and z directions, respectively) and material 2 with constant epsilon2 and dimensions 0.4L*L*d. The dielectric is free to move as a single block without friction along the x axis, parallel to the plates inside the capacitor, and it can also move outside the capacitor. Let us define as x the distance between the dielectric and the edge of the plates, and we can neglect the electric field outside the plates. Considering that the potential difference between two points a and b is delta V= integral from a to b of E.dl, and that D=epsilon0*epsilon(subscript r)*E, where epsilon(subscript r) is the dielectric constant, calculate the value of the electric field E and of the electric displacement field D in the region between the plates, for the three possible regions where the space is occupied by the material 1, the one with material 2, and the vacuum.
attempt at solution:
E=q/(epsilon0 *A)
E=deltaV/d
= integral from a to b of E.dl /d
E=-grad V
but all this seems to be leading nowhere.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
