What Is the Minimum Beam Energy for Proton-Proton Collisions?
J_M_R
Calculate the minimum beam energy in a proton-proton collider to initiate the p+p→p+p+n0 reaction. The rest energy of the no is 547.3MeV.
For a head on collision between particles a and b, from conservation of total energy: Ex = Ep + Ep' = 2Ep
so that mx^2c^4 = Ex^2 - px^2c^2 = (2Ep)^2
[/B]
Rearranging the above, gives mx = 2Ep/c^2
So using the values I have been provided: Ep = (547.3MeV)/2 = 0.2737Gev
I am not sure if my method is correct?
I guess "beam energy" means the total energy, including the rest energy of the protons.
For the additional energy: yes it is correct. The lab frame is also the center of mass frame, so both protons simply contribute half of the n0 energy plus their rest energy.
So to get Ep, I am also required to add the rest energy of the two protons?:
Ep = (547.3MeV + 2(938.3MeV))/2 = 1.212GeV
If rest energy of a proton is 938.3Mev.
Right.
Likes J_M_R
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
