Calculate Power from Water flow
The discussion centers on calculating the theoretical maximum power from water flow for a turbine design. The user initially calculates energy using the kinetic energy formula, resulting in 62.5 kW for a flow of 5 m/s through a 1 m² channel. However, the calculation is incomplete as it does not account for the exit velocity of water, pressure, and gravitational effects. To accurately determine the power output, one must consider the total mechanical power entering and exiting the turbine, factoring in mass flow rate and specific mechanical energy.
  • Understanding of kinetic energy calculations
  • Knowledge of fluid dynamics principles
  • Familiarity with turbine mechanics and design
  • Basic physics concepts including pressure and gravitational effects
  • Research the calculation of mechanical power in fluid systems
  • Learn about specific mechanical energy and its application in turbine design
  • Explore the principles of axial-flow turbine design and efficiency
  • Investigate methods for measuring differential pressure across turbines
Engineers, renewable energy developers, and anyone involved in designing water turbines or optimizing hydrokinetic energy systems.
waterturbine
Hi,
I am interested in building a water turbine.
I am not sure how to calculate the theoretical maximum power that can be derived from a flow.
If I assume I have a flow of 5m/s and a channel (or pipe) 1m^2
then I have a volume of 5,000 l/s
How do I calculate the energy that this flow could transfer to a turbine (excluding losses)?
Ek = 1/2 * m * v^2
water has density 1 so mass of 5,000 l is 5,000 kg
Ek = 0.5 * 5,000 * 5^2
= 2,500 * 25
= 62,500 J
Power = 62.5kW ?
(This doesn't seem correct and it is over 40 years since I did any physics)
So maybe I am missing that the change in flow from input of 5m/s will not be to 0?
Am I missing anything else and is there some other method to resolve this?
Or do I have to determine the Differential pressure across the turbine (I do not have any specs for a turbine yet).
thanks
waterturbine said:
Hi,
Ek = 1/2 * m * v^2
= 2,500 * 25
= 62,500 J
Power = 62.5kW ?
thanks
It's almost that simple -- except (1) the water needs to exit the turbine at some speed, and (2) typically there are pressure and gravity terms that have to be accounted for. You haven't indicated a geometry (is this an axial-flow turbine with equal inlet and exit areas? a centrifugal turbine that extracts gravitational potential energy?) but in general you have to compute the total mechanical power flowing into the turbine and subtract the total mechanical power flowing out, and the difference is the shaft power. The specific mechanical energy (energy per unit mass) is
[itex]P / \rho +gz+V^2/2[/itex]
You have to multiply this by the mass flow rate [itex]\dot{m}[/itex] to get the mechanical power.
BBB
Hi BBB,
thanks for your response,
My applications is generating power from a tidal flow.
I am thinking of building a pontoon that will act as a bi directional shrouded Axial Turbine the inlet and outlet piping will be the same size.
  • · Replies 25 ·
  • · Replies 28 ·
  • · Replies 28 ·
