Calculate Retarding Force of 50kg & 6kg Objects
  • Thread starter Thread starter Taidhg
    Force
The discussion focuses on calculating the retarding force experienced by two objects, a 50kg object and a 6kg object, after a free fall and subsequent impact. Key calculations include the gravitational potential energy (GPE) of 1962J and kinetic energy upon impact of approximately 1961.33J. Participants emphasize the importance of correctly identifying energy transformations and the role of friction after impact. There is confusion regarding the differences in energy values and the necessary information to calculate the retarding force. The conversation highlights the need for clear diagrams and detailed calculations to understand the dynamics of the scenario.
Taidhg
Member has been warned not to remove the template.
1. An object with a mass of 50kg is raised vertically 4 meters above an object of 6kg and then is allowed to fall freely onto the object into the ground. Both objects travel into the ground to a depth of 24cm without rebounding.
Calculate the retarding force causing both objects to come to rest.
KE/GPE = mgh = 0.5m v2
What have you done so far? The relevant equation that you wrote is wrong.
I've calculated the velocity upon the objects impact which is 1.476 m/s2
I also have calculated the GPE before it falls which is 1962J and the kinetic energy upon impact which is 1961.33J
I just don't see how I am meant to calculate this last question.
In all such problems, you should draw a diagram, labeling the different positions. Similarly, label the two balls as A and B. For example, the initial position , with ball A at the top of its path and ball B on the ground can be called position 1. The position just before impact is called 2, and the final position after the two balls sink and come to rest together is called 3.
Your unit for velocity is wrong.
Do you think the kinetic energy in position 2 should be different from the potential energy in position 1?
What information do you need to calculate the last part? How can you get that information?
Please show your calculations in detail.
I really don't know what information I need for the last part that's the issue. I know that the energy used in response to stop the objects will obviously be equal but I've never worked with retarding forces before.
How about friction?
gneill said:
How about friction?
I stated in the original post that the object is in free fall. The question is about a pile driver falling onto a pile but I usually ignore those details.
After the collision occurs, the objects are not in free-fall. The ground is impeding their progress. Friction.
Please show your calculation.
Why are they different?
The energy taken by the retarding force in bringing them to rest will not be equal to the initial GPE. There is energy lost in the impact itself. Have you worked with impacts before?
