Calculate speed from elastic and inelastic collisions? (momentum)
The discussion focuses on calculating the speeds of two trolleys after elastic and inelastic collisions, specifically Trolley A (180g, 4m/s) colliding with Trolley B (120g, stationary). The relevant equations used are V2f=(2m1/(m1+m2))*v1i for elastic collisions and V2f=(m1v1)/(m1+m2) for inelastic collisions. The calculated speeds are 4.8 m/s for the elastic case and 2.4 m/s for the inelastic case, although the elastic scenario is deemed impossible under the given conditions. Participants emphasize the importance of momentum conservation in both types of collisions.
  • Understanding of momentum conservation principles
  • Familiarity with elastic and inelastic collision concepts
  • Ability to apply the equations for momentum and kinetic energy
  • Basic algebra skills for solving equations
  • Study the principles of momentum conservation in collisions
  • Learn about the differences between elastic and inelastic collisions
  • Explore the derivation of collision equations for two-body systems
  • Review examples of collision problems in physics textbooks or online resources
Students studying physics, particularly those focusing on mechanics and collision theory, as well as educators seeking to clarify concepts related to momentum and energy conservation in collisions.
OscarF
Question:
Trolley A, of mass 180 g, is moving at a velocity of 4 m/s towards trolley B which is stationary and has a mass of 120 g. Trolley A then collides with trolley B.
Calculate the speed of trolley B if:
i the collision is elastic (trolley A stops and trolley B moves off)
ii the collision is inelastic (the two trolleys join and move off together).
momentum = mass x velocity
So to cut to the chase, I missed my class' lesson on momentum - have tried to catch up, quite successfully but am baffled about this question. I know the conservation of momentum etc. but after trying for ages it's just not happening this question so any help would be much appreciated,
Oscar.
OscarF said:
Homework Statement:: Question:
Relevant Equations:: momentum = mass x velocity
Oscar.
How much can you do? You need to show us your work.
Note that:
Is not a possible scenario. Which you may be able to prove.
Note that:
Well, from a bit more digging around I came up with these two calculations:
(For the elastic scenario)
(For the inelastic scenario)
V2f=(m1v1)/(m1+m2)
Which led me to the answers:
i) 4.8 m/s
ii) 2.4 m/s
The answer to ii) looks right.
Did you check momentum conservation for i)? What happens to the 180g cart after the collision?
Good point! Will check now, one second.
I just realized... obviously the momentum will not be the same... because for trolley B pre-collision the momentum would be 0 and afterwards it will be whatever 120*4.8 is...
Hmm... I personally wouldn't expect such a twist in a homework like this... Do you think the solution would be to write something like this event isn't possible because...
As I understand it, you are using a formula for the velocity of the second cart in an elastic collision. You must have a similar formula for the velocity of the first cart.
Perhaps whoever set the question made a mistake. In an elastic collision the moving cart only stops if the two carts have equal mass; otherwise, both carts are moving after the collision.
I do have an equation for the first cart - let me just check what that gives as a result in this instance
Hmm... The output results as 0.8 m/s if I do that... Due to the nature of the question, it just feels unlikely that it's a mistake - but you never know - so I have a few options. Either, I just keep it as it is - the answer fine, done and dusted or I add the answer but also add a little note to the side or I can try and talk to my teacher before the homework is due. If I were to right a note about why it's impossible, what would you suggest?
It depends whether your teacher is the sort of person who can accept that he/she made a mistake!
##0.8m/s## and ##4.8m/s## are definitely correct.
They didn't make the worksheet - It's an AQA physics gcse practice question. My teacher's a nice person though - would be fine if I wanted to contest the question!
OscarF said:
Homework Statement:: Question is below
Background:
Unfortunately, I missed my class' lesson on momentum. I've watched this video: https://www.khanacademy.org/science...lisions-ap/v/elastic-and-inelastic-collisions. To try and help me with the following homework - it helped but I still can't really get the answer.
Question:
Any help would be much appreciated,
Oscar.
You just need two general facts:
There being no external horizontal forces on the two trolley system, their total momentum is conserved. Just remember that velocity and momentum are vectors, so direction matters.
If the collision is elastic, total kinetic energy is conserved.
In case ii, KE is not conserved, but you know instead that the two have the same final velocity.
This is enough to find the final velocities. For any further help you must show some attempt.
  • · Replies 16 ·
  • · Replies 18 ·
  • · Replies 21 ·
