Calculate Tension of Two Wires: Physics/Precalc
  • Context: High School
  • Thread starter Thread starter Planetx
    Calculations Tension
The discussion revolves around calculating the tensions in two wires supporting a weight, specifically focusing on the vector magnitudes involved. The context is a high school physics/precalculus problem involving angles and forces.
  • Homework-related, Mathematical reasoning, Conceptual clarification
  • One participant describes the problem setup, including angles A and B and the weight being supported, indicating difficulty in solving the equations.
  • Another participant proposes a relationship between the variables, suggesting an equation for x in terms of y, but expresses uncertainty about the direction of their reasoning.
  • A similar equation is presented by another participant, with a slight variation, who also feels they are not approaching the problem correctly.
  • One participant mentions a common belief that the Pythagorean theorem is straightforward, but questions whether tension behaves differently from magnitude in this context.
Participants express uncertainty and confusion regarding their approaches to the problem, indicating that there is no consensus on how to proceed or what the correct relationships are.
Participants note limitations in their understanding of angle theorems and vector analysis, which may affect their ability to solve the problem accurately.
Planetx
I am tasked to find the tensions of two wires by calculating the "magnitude of the vector" in a high school physics/precalc class. I have tried working out the equation in several ways but they all end up in an unsolvable format. So, in reference to the picture, A = 35 degrees, B= 30 degrees and sides a and b symbolize the magnitude or tension on two vectors when holding a 1200 lbs weight from a level position. I am given no other information.
I have found that x = (-ycos35/cos150) no? And I tried substituting it into a few equations I worked out. I feel I am in the WAY wrong direction here and common sense is failing me.
Planetx said:
I have found that x = (-ycos35/cos180) no? And I tried substituting it into a few equations I worked out. I feel I am in the WAY wrong direction here and common sense is failing me.
I realize this is a simple problem but my application of angle theorem and vector analysis is limited so far.
Some people told me pythagorean theorem is that simple but i figured tension would be different from magnitude
