Calculate the Electric Field at One Corner of a Square
The discussion centers on calculating the electric field at point P, located at the top right corner of a square with three point charges at the other corners. The electric fields due to the charges at corners A and C were calculated to be -22475 N/C each, directed southwest, while the charge at corner B produced an electric field of 112375 N/C directed northeast. The net electric field was computed by vector addition, resulting in a magnitude of 80590.55 N/C directed northeast. Participants noted discrepancies between their calculations and the answer provided, suggesting that the answer sheet may contain an error by incorrectly canceling out the negative charges. The final consensus indicates that the correct electric field magnitude should be around 80,680 N/C, not the 1.1 x 10^5 stated in the answer key.
jumbogala
One side of a square has length 2.0 cm.
In three of the square's corners, there are point charges.
Top left corner: -1.0 nC (call this A)
Bottom left corner: 10 nC (call this B)
Bottom right corner: -1.0 nC (call this C)
The top right corner has no charge, and is labelled P.
What is the magnitude of the electric field at point P?
Electric Field = KQ/r2
Electric Field Due to A:
K(-1.0 x 10-9 C)/(0.02 m2) = -22475 N/C, left
Electric Field Due to C:
Same as above, but this time the direction is down
Electric Field Due to B:
First calculate the distance from B to P. This is 0.022+0.022 = 0.0008. Take the square root of 0.0008 to find 0.0282 m.
K(10 x 10-9 C) / (0.0282)2 = 112375 N/C, at a 45 degree angle pointing north east.
Now, take the sum of all three parts to find the net electric field.
A and C together point south west, with a magnitude of 31784.44 N/C.
112375 N/C - 31784.44 N/C = 80590.55 N/C, north east.
However, the answer given on the page is not what I got. What went wrong?
Remember they add like vectors.
I thought I did add them like vectors.
Adding vectors A (points left) and C (points down) gives a new vector which points south west...
22475^2 + 22475^2 = 1010251250.. take the square root of this and get 31784.44.
Since this vector points the opposite direction as vector B, which is 112375, can't I go 112375 - 31784.44?
So you have. Sorry I just calculated it and I get (5 -√2)*22,500 = 80,680
using k = 9*109
So I can't say what they are looking for then.
I get something similar, but I used K = 8.99x10^9. They are definitely looking for the electric field, but the answer given is 1.1 x 10 ^5.
I think whoever wrote the answer sheet probably made a mistake.
Thanks!
Thanks!
Yes their mistake. They canceled out the -1 nC charges. They don't as described.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 68 ·
