Calculate the p.d. between two points
  • Thread starter Thread starter bsmm11
    Points
The discussion focuses on calculating the potential difference (p.d.) between two points when moving a -8.0μC charge. The work done to move the charge is 8.0 × 10-3 J, leading to an initial calculation of V = -1.0 × 10^3 V. The kinetic energy at point b is 4.0 × 10-3 J, which prompts further calculations resulting in a p.d. of -0.5 × 10^3 V. Participants highlight the importance of understanding the definition of potential difference, specifically whether it is defined as Vb - Va or the reverse, emphasizing clarity in the sign of the result. The conversation concludes with a need for clarification on the correct interpretation of potential difference.
bsmm11
The work done by an external force to move a -8.0μC charge from point a to point b is 8.0 × 10-3J. If the charge initially at rest had 4.0 × 10-3J of kinetic energy ab point b, calculate the potential difference between a and b.
V = W / q
Work done per unit charge to move a positive charge from a to b is
V = W / q = 8.0 × 10-3 / -8.0 × 10-6 = -1.0 × 103V
At a Ek is 0J and at b it is 4.0 × 10-3J, so
ΔEk = 4.0 × 10-3J.
So work done for each electron to give Ek is
V = W / q = 4.0 × 10-3 / -8.0 × 10-6 = -0.5 × 103V
Having Ek means that energy is not dissipated. P.d. is the power dissipated per unit current so
(-1.0 × 103) - (-0.5 × 103) = -0.5 × 103V
Is it right way to do it?
Do I need to get rid of negative sign when I calculate the p.d.?
The result is correct, but look after how is potential difference between a and b defined. Is it the potential at "a" minus potential at "b" or the opposite? The best thing is to make it clear, giving Vb-Va, or saying which point is positive with respect to the other point. So which one?
ehild
