Calculate the "surface energy" of succesively smaller cubes
The discussion revolves around calculating the surface energy of NaCl as it is progressively broken into smaller cubes, starting from a single cube of 1 g. Participants explore the implications of the given surface energy and density, and how to apply the provided formula for surface energy in this context.
  • Homework-related
  • One participant expresses confusion about the initial surface energy value given for the single cube and whether it should be assumed as the starting point for calculations.
  • Another participant clarifies that the task is to find the total surface energy rather than a specific surface energy per unit area.
  • A participant seeks clarification on the formula for total surface energy and whether density or mass should be used in calculations.
  • One participant indicates that they were able to solve the problem after receiving assistance from others.
There is no consensus on the interpretation of the problem's requirements initially, but participants generally agree that the goal is to calculate total surface energy. The discussion reflects uncertainty regarding the appropriate formula and how to apply the given parameters.
Participants note potential issues with the scale of the x-axis for plotting surface energy against cube size, as well as the relevance of the formula provided in relation to the size of the cubes being considered.
Students working on problems related to surface energy in materials science or chemistry, particularly those involving calculations of energy as a function of size in solid materials.
Jacob Daniel
NaCl has a density of 2.16 g/cm3 and a surface energy of 2x10-5 J/cm2. Calculate the surface energy of 1 g of NaCl. Initially the complete 1 g is in the form of a single cube (of mass 1 g) and progressively broken into smaller cubes with sides of 0.1 cm, 0.01 cm, 10 μm, 1 μm, 100 nm and finally 1 nm.
Make a plot of surface energy vs size of the cube.
The surface energy of a new surface can be calculated based on the equation discussed in class:
γ = (1/2)Nbερa
Where Nb is the number of bonds broken to create the surface, ρa is the number of atoms per unit area of the new surface and ε is the bond strength.
This question makes absolutely zero sense to me. 1st of all, it asks me to calculate the surface energy of 1 g of NaCl that gets broken into smaller and smaller cubes, but it gives a surface energy at the start. So am I supposed to assume that 2e-5 J/cm2 is the surface energy of the single cube before it gets broken up?
Also, note how it wants me to make a plot but the scale of the x-axis is way out of wack. I'm going to have to plot a point at 1 nm and plot another at 0.1 cm which is equivalent to 1,000,000 nm!
I had to edit out grammar mistakes from this question. Another thing that pissed me off was that the prof wrote the shorthand for gram as gm instead of g. I know this is irrelevant but I had to vent a little bit.
I don't see how the formula for surface energy comes in handy because it assumes we are cutting into a unit cell on the molecular level, however the question clearly indicates that we are dealing with relatively big cubes of salt.
I don't even really know where to start. I'm not expecting anyone to make the plot for me. I just want to know how to calculate the surface energy with the variables I have been given. Thank you all very much.
You are asked to find a total surface energy, not specific (per cm2).
Oh ok. So the mass will always be 1 g but at 1st it will be one big cube, then an increasing number of smaller cubes. And the question is asking me to find the total surface energy.
My only question now is what is the formula for total surface energy. If I know which formula to use, then the rest is easy. I looked through my notes but I can't find a formula to use. Am I supposed to use the density and/or the mass in some kind of conversion pathway to arrive at the solution? Which will be in units of joules, not joules per cm2?
Thanks to your help, I was able to solve the problem. Thank you.
  • · Replies 28 ·
  • · Replies 16 ·
