Calculate the vertical motion of a piece of debris from an explosion
The discussion focuses on calculating the maximum altitude of a piece of debris launched at a speed of 5.3 km/s from an explosion. For the first part, the user derives the maximum height using the equation h = v^2/(2g), relating kinetic energy to gravitational potential energy. The second part involves using gravitational potential energy, where the user struggles to correctly apply the formula U = -GMm/r and its implications for energy conservation. The conversation emphasizes the need to understand the differences in potential energy at the launch point and at the peak altitude. Overall, the thread highlights the complexities of applying physics principles to real-world scenarios.
starstruck_
< Mentor Note -- thread moved to HH from the technical physics forums (because of a forum issue), so no HH Template is shown >[/color]
There was a huge explosion, one small piece of debris was launched upward at v=5.3 km/s. Calculate its maximum altitude.
a) Develop an expression for the maximum altitude assuming the change in potential energy = mgh
b) derive an algebraic expression for the maximum altitude using U= -GMm/r.
For a) I set 1/2mv^2 = mgh, therefore
h= v^2/(2g)
I’m not exactly sure how to work with b.
I wasn’t there for this lecture. This is what I’m assuming and I’m most likely understanding this incorrectly. -GMm/r would be equal to the change in potential energy I guess? Which would be 0- 1/2mv^ = -1/2mv^2? I set that equal to -GMm/r? I’m not completely sure.
You have a U0 (potental energy at launch point), then a Ufinal (potential energy at the peak. You need to find the difference between those.
From what I’m understanding :
Etotal 1= E total2
1/2mv^2 - GMm/r (potential energy assuming it is on the surface when it explodes)
= 0- GMm/r+h where h is its altitude above the surface of the Earth ?
Etotal 1= E total2
If you mean 0- GMm/(r+h), yes.
Likes scottdave
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
