Calculate the voltmeter reading
  • Thread starter Thread starter moenste
    Reading Voltmeter
The discussion focuses on calculating the voltmeter reading (Vm) in a circuit with a light-dependent resistor (LDR) under moonlight conditions, where the LDR has a resistance of 800 Ω. With the switch S open, the total resistance is 1000 Ω, leading to a current of 0.01 A and a voltmeter reading of 8 V across the LDR. The second part of the problem determines the resistance R when the switch is closed in daylight, resulting in a calculated value of 50 Ω. Participants clarify the role of the switch versus a diode, emphasizing that a switch acts as a zero resistance connection. The final calculations and logic presented are confirmed as correct.
moenste
The light-dependent resistor (LDR) in the circuit below is found to have resistance 800 Ω in moonlight and resistance 160 Ω in daylight. Calculate the voltmeter reading, Vm, in moonlight with the switch S open.
If the reading of the voltmeter in daylight with the switch S closed is also equal to Vm what is the value of the resistance R?
Answers: 8.0 V, 50 Ω
2. The attempt at a solution
At first I would like to check whether I understand the scheme correctly. The switch S is a diode (open is a reverse-biased and closed is a forward-biased). The LDR is just a regular resistor, just need to take into account different values of resistance depending on the daytime. Should this be correct?
I this representation correct?
A switch is not a diode. A switch will pass current in either direction with equal facility and does not exhibit a potential drop when current passes through it (at least for an ideal switch). Diodes pass current in one direction only, and except for ideal diodes cause a potential drop on the order of a half volt when they do.
It's better to think of a switch as a zero resistance wire connection that can be inserted or removed manually.
Your redrawn circuit is fine.
Likes moenste
We need to find the voltmeter reading during moonlight when the resistance is 800 Ω and the switch is open. If the switch is open, the resistor R is shut off. Therefore we have only two resistors 200 + 800 = 1000 Ω. I = V / R = 10 / 1000 = 0.01 A. Now we find the 200 Ω has V200 = I R200 = 0.01 * 200 = 2 V, and the LDR resistor, as a result has 8 V. Since the voltmeter is connected to LDR, its reading is 8 V. Correct logic?
Update: for the second question we have: since the reading doesn't change, therefore V = I R and we can find I = V / R = 8 / 160 = 0.05 A of the whole circuit. Then, knowing V = 2 V and I = 0.05 A, we find the RParallel: R = V / I = 2 / 0.05 = 40 Ω. Then, by 1 / R = 1 / R + 1 / R → 1 / 40 = 1 / 200 + 1 / R → R = 50 Ω. Should be correct.
That all looks good. Well done.
Likes moenste
  • · Replies 17 ·
  • · Replies 25 ·
11K
15K
  • · Replies 25 ·
10K
