Calculate the Volume of a Lemonsqueezer
  • Thread starter Thread starter Elpinetos
    Volume
4 replies · 2K views
Elpinetos
[itex]f(x)=\frac{1}{81}*x^4-\frac{5}{9}*x^2+4[/itex]
The tangent in Point P(6|0) when rotated around the y-Axis gives the Shape of the Squeezer. The bottom is at y=-5, the top at y=0
First I calculated the tangent and got
[itex]t: y=4x-24[/itex]
Then I converted that to [itex]x^2[/itex] since I need that for the rotation around the y-Axis
[itex]x^2=\frac{y^2}{16}+3y+36[/itex]
Then I rotated it:
[itex]V=\pi\int\frac{y^2}{16}+3y+36dy = \pi(\frac{y^3}{48}+\frac{3y^2}{2}+36y)(0 to -5)[/itex]
[itex]= \pi(0+0-(-\frac{125}{48}+\frac{75}{2}-180) = \pi(\frac{125}{48}-\frac{1800}{48}+\frac{8640}{48})[/itex]
[itex]= \frac{6965\pi}{48} = 455.86[/itex]
Since this is in cL, which would equal around 4.6L I find the result a bit excessive. Have I made a mistake somewhere? Can someone please check for me? Thank you in advance :)
Then I rotated it:
No mistake. That is correct.
Elpinetos said:
4.6L Lemonsqueezer? Okay thank you^^
The problem states nothing about units. You can tell the 455.8 is reasonably close since the volume would be a bit less than a disk of radius ##6## and thickness ##5##$$
5\pi 6^2 = 565.48$$
Yeah it does. It states 1 unit = 1cm and the Volume in cl
Thank you though :)
