Calculate the z component of the torque relative to position
To calculate the z component of the torque relative to position A, the torque equation T = r × F is essential, where r is the position vector and F is the force vector. Each force, such as F1, contributes to the torque, and the z component is determined using the right-hand rule, with clockwise torques being negative. The calculation for the z component involves the formula -|F1*h|z, indicating that the torque is negative due to its clockwise direction. It is important to sum the torques from all forces to find the net torque.
magma_saber
http://img3.imageshack.us/img3/5681/32832.jpg
All seven forces have a magnitude |F| = 32 N. w = 10 m, h = 16 m, and d = 15 m. Calculate the z component of the torque relative to position A.
T = r*F
Not sure how to start this.
F1 = F*h*w = 32*16*10?
F2 = F*h = 32*16?
T = r X F
So you want to figure the force acting at a perpendicular to the point at interest.
In this case your r X F1 will equal |F1|*h, where h is the distance at which it is acting ⊥ to a line through A.
LowlyPion said:
T = r X F
i tried that, its wrong. it says the z component. would that make a difference?
The resultant of r X F is a z component by the right hand rule for taking a cross product.
Of course you still need to sum up all the other torques from the other forces.
it asks just for the torque for each force that is applied, i.e. F1, F2, F3, ect. After that, it asks for the net torque. for F1 i tried F*h and it was wrong. Would it be F*h*w, since the tail starts at w?
Sorry I thought you were supposed to be determining the sum.
The |T| is F1*h. But because it is the cross product of y X x, that yields a clockwise torque that is -z
So for F1 you have the z component is -|F1*h|z
Counterclockwise torques are positive. Clockwise are negative.
http://en.wikipedia.org/wiki/Right-hand_rule
  • · Replies 25 ·
  • · Replies 16 ·
  • · Replies 18 ·
  • · Replies 18 ·
