Calculate Upper and Lower Sums for Variable Intervals
  • Thread starter Thread starter Uniquebum
    Sum
4 replies · 2K views
Uniquebum
Let [itex]f:[0,1]->ℝ[/itex] and [itex]f(x) = \frac{1}{n}[/itex] when [itex]x=\frac{1}{n²}, n=1,2,...[/itex] and 0 in other case.
Define such spacing/interval [itex]D[/itex] that [itex]S_D-s_D < \frac{1}{100}[/itex]. Here [itex]S_D[/itex] refers to the upper sum and [itex]s_D[/itex] the the lower sum.Now, I'm not sure how to approach this really since the sum is defined so that the values of x jump a different interval every time. Any help would be appreciated. Hopefully i managed to explain the problem clearly enough.
That looks like a typo.
Is [itex]\displaystyle f(x) = \frac{1}{x}[/itex], when [itex]\displaystyle x=\frac{1}{n^2}, n=1,2,...[/itex] and 0 in otherwise.
... or perhaps ... [itex]\displaystyle f(x) = x[/itex], when [itex]\displaystyle x=\frac{1}{n^2}, n=1,2,...[/itex] and 0 in otherwise.
Are you doing this with Riemann sums ? ... and ... Do the intervals need to be equal in size?
It actually is [itex]f(x)=\frac{1}{n}[/itex]. Yea, I'm trying to approach this with Riemann sums and the intervals don't need to be equal in size as far as i understand.
Right, I gave it a wild shot and this is what i came up with.
The upper sum is defined as
[itex]\sum_{k=1}^{n}(x_{k+1}-x_k)*sup(f(x))[/itex]
Now let's choose such width for the Riemann sum quadrilateral that
[itex]0.5*(\frac{1}{n} - \frac{1}{n+1})= \frac{1}{2n(n+1)} = r_n[/itex].
Lets place each quadrilateral so that the supremus (=the point 1/n) is in the middle. This way the infimum will always be 0 and the lower sum [itex]s_D=0[/itex].
Calculating the upper sum gives
[itex]\sum_{k=1}^{n}(x_{k+1}-x_k)*sup(f(x)) = \sum_{k=1}^{n}(2*r_n*\frac{k}{n})[/itex]
because [itex]\frac{k}{n}, k=1,...,n[/itex] goes through all the supremums.
So
[itex]S_D = \sum_{k=1}^{n}(2*r_n*\frac{k}{n}) = 2*r_n\sum_{k=1}^{n}k[/itex]
which with a little work leads into
[itex]S_D = \frac{1}{2n}[/itex] since [itex]\sum_{k=1}^{n}k=\frac{n(n+1)}{2}[/itex]
Now [itex]S_D-s_d=\frac{1}{2n}-0=\frac{1}{2n}<\frac{1}{100}[/itex] when [itex]n\geq 50[/itex].
Whether that's right or wrong is beyond me...
I'm actually starting to wonder whether it might be a typo by my professor.
Since it seems the function would only get one value if defined the way i stated in the original post. [itex]\frac{1}{n}[/itex] right?... or?
