Calculating 0-60 mph time for a vehicle
  • Level: Undergrad
  • Thread starter jumpjack
    Time Vehicle
76 replies · 30K views · last reply
jumpjack said:
Yes, traction is constant, but air drag is not, hence the equation which uses K1 and K2. But why doesn't it work?!?
I wouldn't bother with drag here. While drag is a significant fraction of your engine load when cruising at 60 mph, it is an insignificant fraction of engine load when accelerating to 60mph. A car that gets 30 mpg is putting out only about 17 hp in cruise.
The fact that there are multiple drivers (tire friction, torque or power, gear ratio) and multiple levels of complexity would lead me to approach this problem with a numerical analysis in Excel. That way, you can start off simple and add complexity later, without losing what you already have. And Excel can figure out on its own, with if-then statements, when the transition between traction limited and engine limited acceleration happens and when the gear shifting happens.
I need an equation which takes into account drag and friction.
The differential equation you have in the last post, with acceleration equal to the sum of terms proportional to velocity and velocity squared and a constant pretty much covers it. It's not going to be easy to compute real world coefficients without a wind-tunnel and telemetry though.
A real car loses energy to the environment in many different ways. Laminar air flow, turbulent air flow, road noise, engine noise, heat, etc. The equation you have been given for drag is a decent approximation for something like a lorry traveling at high speeds. At lower speeds for a car it's not going to be a good approximation. Cars are designed aerodynamically, to take advantage of this.
You can't realistically derive the contribution from these terms from first principles, but I'd expect there to be a spectrum of terms proportional to different non-integer powers of velocity. Even if you did find away to compute the coefficients for each term, you wouldn't solve such a differential equation analytically. A better approximation would be to use an empircially determined power to raise the velocity in the drag term to, which depends on the aerodynamics of the car. You can throw all your other loss terms in here too.
As already suggested, it is known that it is relatively safe to approximate these terms away under full acceleration and low-to medium speed, for a car, but as you approach maximum speed, those terms become equal to the acceleration term provided by the engine.
May I ask why? What is the purpose of this inquiry?
And because of the fact that you have to account for traction and shifting, I'm not sure what you are asking is even possible.
russ_watters said:
I wouldn't bother with drag here. While drag is a significant fraction of your engine load when cruising at 60 mph, it is an insignificant fraction of engine load when accelerating to 60mph. ...
I agree.
Here is my simplified formula (for electric cars) obtained by finding the best fit in Excel:
##t_{60}=\frac{2.79 m}{P^{0.46}T^{0.72}}##
where m is the kerb weight in Kg, P is the max power in kW and T is torque in Nm.
This is a table for performance of electric cars obtained from an earlier post with some modifications and additions:
Data for electric cars:
kg, kW, Nm, top mph, sec to 60mph*, predicted ##t_{60}##
Smart fortwo electric drive 900, 55, 130, 78, 12.9, 13.5
Mitsubishi i-MiEV 1185, 47, 180, 80, 13.5, 13.4
Citroen zEro 1185, 47, 180, 80, 13.5, 13.4
Peugeot iOn 1185, 47, 180, 81, 13.5, 13.4
Renault Zoe 1392, 65, 220, 84, 13.5*, 12.4
Renault Fluence Z.E. 1543, 70, 226, 84, 13.7*, 12.8
Nissan leaf 1595, 80, 280, 93, 9.9, 10.3
Toyota RAV4 EV 1560, 115, 296, 100, 8.0, 8.2
Tesla S 1999, 225, 430, 120, 5.9, 5.9
Tesla S Perf 2108, 270, 440, 125, 5.4, 5.6
Tesla S Perf Plus 2108, 310, 600, 130, 4.2, 4.2
The Chevrolet Volt and Toyota Prius have been removed from the table as they are hybrid cars with internal combustion engines and the Tesla models have been added to increase the range of data in the table. It should be noted that it is not always clear if the manufacturers include battery weight in their quoted kerb figures and legislation does not appear to have caught up with how the kerb weight of electric cars is defined.
* The Renault 0 to 60mph figures have been highlighted as they are actually figures for 0 to 62mph and because there is some variation on the figures quoted depending on the source. These are the sources I used: http://www.motorline.co.uk/renault/pdfs/fluence-ze.pdf and http://www.carfolio.com/specifications/models/car/?car=342397
jumpjack said:
Just consider electric vehicles: constant torque, no gears, motor efficiency =~100% .
In a second instance we could investigate Power/Torque correlation in electric motors.
While the lack of gears for electric cars simplifies the calculations, there is still an effective gear ratio in the drive train from the motor to the wheels and this varies from model to model. This is not taken into account in my simplified formula, as this information is not readily available (but I haven't looked that hard). I am also assuming that not all electric cars are direct drive. Maybe none are? Anyone know?
Including the top speed in the calculations would help the accuracy as it gives an idea of how efficient the aerodynamics of the car are and the overall gearing of the car, but if you are going to the trouble of finding the top speed on a test track, you might as well test the 0 to 60 mph times while you are there.
jumpjack said:
Without air friction (not what I am looking for, but useful for comparison and for the example):
$${ t_{60} = \frac{P_{max}}{2 m \epsilon^2 g^2} + \frac{m v_{60}^2}{2 P_{max}} } $$
This equation predicts a 0 to 60 mph time of 7 seconds for the Tesla S performance and 7.2 seconds for the Performance Plus, yet the Plus has significantly more power and torque and the same weight. Something not right there. Tesla claim 5.4 seconds for the Performance and 4.2 seconds for the Plus.
craigi said:
You can't realistically derive the contribution from these terms from first principles, but I'd expect there to be a spectrum of terms proportional to different non-integer powers of velocity. ..
If I said I had 4000 kg electric vehicle with a 2 hp motor that did 0 to 60 mph in 3 seconds on the flat without a following wind, you would say that not physically possible. Even if you did not know the drag coefficient or gearing ratio or drive train efficiency of the vehicle, you would still probably think it was bull$3#!. However it appears no one on this forum can present a formula to show the above claim is impossible. There must be simple equation that give the theoretical minimum 0 to 60 time for a vehicle based just on the power, torque and weight before factoring in losses due to friction and drag, surely? Come on guys, get it sorted!
P.S. there is a related thread here https://www.physicsforums.com/showthread.php?t=746796
Participation in this forum is not compulsory. Some of us can spot the threads where we just don't want to go there - too many errors being made by people with too many fixed ideas.
Proving your scenario is impossible is trivial. A 2hp motor is about 1.5 kW. 60 mph is about 27 m/s.
The maximum work done by the motor in 3 sec = 4.5 kJ.
The kinetic energy of a 4000 kg car at 27 m/s = 1458 kJ.
Thanks! Now we are getting somewhere. That is a good place to start.
jumpjack said:
Just help if you can, don't argument.
Thanks.
I reword my question:
I have a vehicle with given power and torque, say 100 kW / 100 Nm motor. Known it's Cd,frontal area , Crr (rolling friction coefficient) and mass, which is the minimum time it can achieve to go from 0 to 60 mph?
There's no point in getting cross when someone points out that this is not possible - by the definition of Power from Torque and speed. You would be better to stop at this point and get your definitions right before moving on.
Why not just find out the tyre diameters and try fitting:
t = km/Td
where
t is the time
k is a constant
m is the mass
T is the engine torque
d is the tyre diameter
It's much simpler and actually based on the physics that we've been discussing.
The engines start to lose torque at a certain speed, which I think will be less than 60mph in all cases. I think it's safe to presume that once they start to lose torque, they all output a constant power upto a speed beyond 60 mph, so I think we could construct a more sophisticated formula. That should provide an even better fit.
We'd be looking to solve a 2 part differential equation:
a = d/2m T where T <= Pd/2v
a = d/2m Pd/2v where T > Pd/2v
where P is the maximum engine power, a is acceleration and v is speed.
The first part solves trivially and provides the boundary condition for the second
Sure there's rolling friction and air resistance etc, but until we've actually got the driving force correct, there's no point worrying about those.
Engine torque and tire diameter are irrelevant until you specify the details of the gear ratio between them. That is one reason that both formulas above are wrong.
If you postulate a fixed gear ratio of one to one and an engine which achieves peak torque from 0 rpm all the way up until it reaches its given maximum power and which achieves peak power at all higher rotation rates then your equations would be closer. But still wrong.
For a fixed torque at the drive axle, acceleration scales down with tire diameter, not up.
t = km/Td
where
t is the time
k is a constant
m is the mass
Most of your assumptions are wrong here. I don't mean to mean, they just are. For one, the engine torque does not equal the tire torque. If we are in top gear, then the tires normally have half the torque then the engine, because they are turning twice as fast. The power at the engine is also never constant unless the torque is changing a specific way that only happens with certain electrical engines. Those special electrical engines are never put on vehicles. Some electrical vehicles do try to use constant torque, which means the power goes on a linear climb as the gears get faster until you get so fast that torque and power have to be dropped down to zero to save the car from melting. The gear shift is normally arranged to change before you hit this power drop.
What we can assume is that the power coming out of the engine will be conserved. That work done in a time frame has to go somewhere. On average, you should lose about 16% to the driveline. The rolling friction will change based on a mix of gravity and downforce from aerodynamics. To make things easier, you can just find an average to apply here. The aerodynmics have a cubic increase in power loss as velocity increases. If you take engine power, subtract drive line loss, subtract rolling friction, and subtract aerodynamic drag, then you should have the power at the wheel propelling you forward. If you have the power at the wheels, which will be different than the power at the engine, then you can take the wheel diameter and determine the torque, RPM, and distance traveled per rotation. It's a complicated process that I've just started to break down here:
Test Driving a Car Virtually
I'll be updating it every few days with a few more equations to figure this all out.
You know I take that back. Power can be constant on a CVT. A CVT actually constantly changes the gear ratio's to keep the engine at the same speed as the tires change speed. Whether they set it up for RPM's at peak torque or peak power will depend on if they care more about fuel economy or acceleration. The torque at the wheel still constantly changes, because the wheels don't always spin at the same speed. The same power applied over different speeds changes the torque. Though if you made the assumption that you were working with a Constantly Variable Transmission, you could cut out the gear ratios.
That is specifically what we were talking about and it does match the torque and power curves for many electric cars very well. The Fluence Z.E, for instance, has flat torque upto about 25 mph, followed by flat power up to about 70 mph.
You're totally right that there are errors in those equations, without an extra piece of information such as angular speed of the engine at max power or specifics about tranmission, I don't think I can fix them.
I cannot imagine why you would want to be working at anything other than as near Maximum Power as you can at all times. This would have to involve a many step / infinitely variable gearbox. Of course, the torque to the wheels will drop off, pro-rata with speed but that's basic Mechanics.
What you are describing doesn't make sense according to the laws of physics. We know speed is going up, because you say that the car is going from 25mph to 70mph. We know the Flunce Z.E. doesn't have a continuously variable transmission, and you are saying you want to assume it is in one gear. So the engine speed has to increase when the vehicle speed increases. To increase speed at the same power, you have to constantly lower torque. The problem is that you are describing a car with a synchronous electric engine, so in order to have the characteristics you describe, you would have to decrease the electrical charge of the poles in the motor, which means you would be purposely making the motor less efficient. Now motors of this type do have a steep drop off in efficiency at a certain point, but why would they purposely make this efficiency drop off just to maintain a linear torque drop. If what you are saying is true, then the engine in this car is purposely made to run inefficiently.
RedRook said:
The problem is that without changing gears either speed or torque has to go down to maintain power. We know speed is going up, because you say that the car is going from 25mph to 70mph.
This is correct. The torque falls off as 1/v when maximum power is reached. It's not a deliberate torque reduction, it's just what happens when you achieve a constant power output.
If your system can deliver the torque and power curves that we're talking about, there isn't the same need for gearing as with combustion engines.
It's moving a heavy load, running off a battery. You're not going to be able to treat your power supply as ideal. I don't think there's a purposely introduced power limit, rather it's a feature of the system when you consider it as a whole. There's undoubtedly circuitry between the battery and the engine. I would suspect that its purpose is to optimise the power output of the engine, without causing damage to the coils.
It's also worth noting that you can make an easy sanity check, without getting involved in deriving the back EMF as a function of angular speed. It's easy to see that in order to keep the torque finite, the power curve for any engine under load, must start at zero and contain no discontinuities. So we already know that the current and voltage of the motor can't be constant and must build up with velocity.
Ok, the problem here is the engine power drops off if you start adding a drop in voltage. This is the steep drop off point I mentioned. I'm aware of this point, but this point does not equal constant power. Your torque is dropping at that point, because your power is dropping much faster than the engine is increasing in speed. Torque is not dropping linearly though. From the curves I've seen, Torque drops at an increasing downward curve as your power falls off. Where we might be getting confused here is the power output of the electricity powering the engine compared to the power output of the engine. They are not the same thing. When you reach the maximum power being produced in electricity, you definitely reach a flat power curve for the electrical power output. That does not mean you've reached the maximum power for the engine. The maximum power for the engine can be reached before the maximum power output of the electricity. The inefficiency is generally made possible by slippage. This slippage accounts for the difference in power being applied by electricity and being observed on the rotating engine. You also will notice this car still has a gear box. The reason is that the power curve of this electrical motor does not extend far enough to allow for one gear. Eventually you are going to hit the wall on how much electrical power you can generate. At this point, you can only keep making the car faster by shifting gears. We would only lose the need for a gearbox if you had an electrical engine that could go from 0 RPM's to the amount of RPM's needed for max speed without running out of electrical power. I believe the Tesla amazingly has an engine with this capability. If drag wasn't an issue, even the Tesla could be made to go faster if you started adding gears. The gearbox 5-speed I see listed though means the car you are talking about has 5 gears ratios.
HP = V * I * Eff / 746
HP = power
V = voltage in volts
I = Current in amps
Eff = efficiency
Also if you are talking about the electrical power output, I do see several graphs online that show that curve with a climb followed by a flat spot at the top until the redline for the gear speed is reached. That might be what is making you think there is a flat power curve.
Nope. No one suggested that it does. Like I said, when constant power is reached, it drops as 1/v.
There isn't sufficient energy loss to affect the shape of power curves.
Are you sure about this? The manufacturer's website says that there is no clutch or gearbox.
I'm talking about the engine power and torque curves.
Ok, you might be right about the gear box. I couldn't find the spot on the Renault site that gave the transmission details, so I looked on other sites. I went back to those sites, and I saw they also mentioned a petrol engine. They are obviously talking about a different car. When I finally got to the brochure on Renault, I found that it has a continuously variable transmission. So it doesn't have one gear. It has always changing gears, so that would certainly make sense for a constant power. What you are saying is entirely possible with a CVT. The constant power characteristic wouldn't be coming from the fact that this is an electric car though. A petrol car with a CVT can have constant power as well. The constant power comes from the transmission.
Yes, this is not the only wrong formula: also the one which takes into account air drag gives impossible results (more than 60 seconds to go from 0 to 60 mph!)
Ok, I add some clarification and set some basic hypotheses from which to start from.
This is the typical output of an electric car (brushless motor):
Torque versus speed graph for a BLF series brushless motor, showing a limited duty region above and a continuous duty region below a rated torque line, with four numbered callouts on wide speed range, flat torque, max 2 times torque and speed regulation.
This is the actual, "physical" torque/speed curve for a dc/brushless motor:
Graph of torque in oz-in against speed in rpm, a straight line falling from stall torque at zero speed to zero torque at no-load speed, with an operating point marked on the line.
Unfortunately, you can't exploit the whole curve from 0 rpm (stall torque) to no-load speed (= 0 Nm torque), because at stall torque you would have something like THOUSANDS of amperes in your motor, which, guess what, would melt it; so a "rated torque" is fixed by electronic (first picture).
When you read "CVT" for electric cars, they just mean "automatic gear", i.e. you have a gear stick with just three positions: Drive, Neutral, Rear ("standard" people does not need technical details about how CVT is accomplished: if by complex mechanics or just by an electric motor directly placed into the wheel (hub motor), or an electric motor directly connected to differential gear).
I know how actually "electrical CVT" work because I drove 6 different electric cars by myself, I own an electric scooter declared by manufacturer as "CVT", and I also wrote a book on this topic.
This said, I think that to solve the original question, we should really simplify the problem.
In a first instance, let's ignore rolling friction: in worst case, it can increase the 0-60 time, but we currently have too LONG time with all equations we found, so it does not help in finding right equation.
Then, let's consider torque as constant from 0 to 60 mph: again, once we'll add real torque/speed data, we'll get a LONGER time, and again we are not looking for a longer time, 60 seconds to go from 0 to 60 mph are already too many!
I think we should work&think about the actual torque applied to wheel and the actual contribution of air drag to the force expression and speed equation, because there must be something wrong here.
We could also fix a lower limit to the 0-60 time be means of energy balance: a 1500 kg car needs amount of energy to go from 0 to 60 mph which is given by:
E = 0.5 * 1500 * 27.9 * 27.8
How do we get 0-60 times for the final-energy vaue?
Where did you get these data?
Once we'll find a "best case" result for 0-60 time, we could take into account the real torque/speed curve of an EV:
http://img534.imageshack.us/img534/146/005elecnogears.jpg
Compared to an ICEV curve:
http://img841.imageshack.us/img841/772/004icegears.jpg
Of course this will give longer times, but as I said, we are currently trying to REDUCE time resulting from our current formulas, because even the worst car requires st most 30 seconds to get from 0 to 60 mph, but we get 60+ seconds with our (wrong) formulas.
http://www.energeticambiente.it/vei...re-elettrico-per-veicoli-3.html#post119396037
To be able to check if manufacturers data about acceleration are plausible; for example I read that Start Lab Open Street (a neighbour electric car) is capable of accelerating from 0 to 50 km/h in 3.3 seconds, which I know it's impossible, but only because I drove several vehicles like that one, and I measured that they require up to 20 secs if they carry lead battery and 6 seconds if they carry lithium battery.
I'd like to be able to figure out which real performances of a vehicle are without need to test it...
yuiop said:
I agree.
This is an interesting formula... but how did you get to it? "Best fitting" what? And how?
Found some actual charts:
Line graph titled Tesla Model S Power and Torque, plotting power and torque (kW, Nm) against speed (mph) from 0 to 130. Solid lines show torque and dashed lines show power for the S60, S85 and P models, each peaking at a plateau then falling as speed rises.
Line graph of torque (lb-ft, wheel torque) against speed (RPM x1000, mph) for two Roadster Sport Electric Motor setups, one red and one blue, with the blue 2-speed curve extending to higher speed.
  • Chart titled 5A Gen2 ZOE plotting torque in Nm and power in kW against speed in km/h; torque rises to a plateau near 220 Nm then falls with speed, power rises then holds near 63 kW. Note reads Couple max / max torque: 220 Nm, Puissance max / max power: 63 kW.
  • Chart titled Fluence Z.E. plotting torque in Nm and power in kW against speed in km/h from 0 to 135. Torque rises to about 226 Nm, holds to about 35 km/h, then falls. Power rises to 70 kW at about 40 km/h, holds to about 110 km/h, then falls. Labels read: Couple max / max torque : 226 Nm; Puissance max / max power : 70 kW.
How do we get 0-60 times for the final-energy value?
Basically we equate the input energy over the acceleration period to the final kinetic energy, so;
##Pt = \frac{1}{2}Mv^2##
[itex]\Rightarrow t = \frac{1}{2}\frac{Mv^2}{P}[/itex]
If P is the maximum power and if this could could be delivered right from zero mph then the time given by the above formula represents the absolute theoretic minimum acceleration time, but in practice, as you know, the power has to ramp up with the revs and velocity of the vehicle and so we have to find a reduced value for the power representing an averaged figure and taking losses into account.
Basically by trial and error and using the solve function in the Excel software. I have gathered together some more data for electric cars and found a better formula. The new equation is:
##t = \frac{1}{2}\frac{M v^2}{P}+\frac{1}{2}\frac{M^{0.48} v^2}{P^{0.48} T^{0.48}} ##
where v is the final velocity (26.8 m/s), P is the maximum power output in Watts, T is the maximum torque in Nm and M is the Kerb weight plus 75 kgs to take account of the driver's weight. The first term represents the bare minimum possible time and the second term represents additional time due to power ramp up, friction and how the the torque curve relates to the power curve. The table below shows an extended table of electric cars and their 0-60 mph times together with the predicted time (t60 column) and the percentage error of the predicted value from the published time in the yellow columns.
Table of electric cars listing Kerb weight kg, power kW, torque Nm, 0-60 time, predicted t60 and percentage error, with yellow highlighted predicted and error columns.
The average absolute deviation of predicted values from the published values is about 6% which is not bad considering the very wide range of vehicle weights, power and torque outputs in the table. Generally acceleration is considered to be mainly a function of power to weight ratio, but it can be seen that some cars have faster 0-60 times than other cars that have a higher power to weight ratio, so torque has to be taken into account.
I have found an exception to the above formula where the error margin is unacceptable. It is the million dollar RIMAC Concept One super car which has 1088 horse power (!) and 1600 Nm torque. The predicted 0-60 time is 1.5 seconds whereas the actual time is 2.6 seconds. I am assuming that the RIMAC does not have sufficient traction to transfer all of that extreme power to the tarmac efficiently despite having 4 wheel drive. Actually, this video would suggest that traction IS an issue for the RIMAC. A lot of the energy is going into smoking the tires and melting the tarmac. Still, 2.6 seconds is not to be sneezed at!
jumpjack said:
To be able to check if manufacturers data about acceleration are plausible; for example I read that Start Lab Open Street (a neighbour electric car) is capable of accelerating from 0 to 50 km/h in 3.3 seconds, which I know it's impossible, ...
Your neighbours claim may be plausible. he is saying it take 3.3 seconds to go from 0 to 31 mph. Since the kinetic energy is proportional to v^2 the time to get to 31 mph (50 kph) is much less than half the time it takes to go from 0 to 62 mph (100 kph). I would say that 0-31 mph in 3.3 seconds would be consistent with 0 to 62 mph in about 11 seconds which is mid range in the above table.
  • Table of electric cars listing kerb weight in kg, power in kW, torque in Nm, published 0-60 mph time, predicted t60 in seconds and percentage error, with the predicted and error columns highlighted in yellow.
No it's not: I forgot mentioning it has a 4 (yes, four) kW electric motor! :-)
Thanks for the new equation and table.
About the RIMAC Concept One... it's not easy to keep wheels in contact with the road when they try to give 1.9 g acceleration to the car! (27.8 m/s / 1.5 = 18.53 m/s2)
Even 2.6 secs mean 1g!
I think it's not very comfortable for passengers... ;-)
Maybe we could try taking into account the non-constant curve to get better results:
http://www.renault.com/fr/innovation/gamme-mecanique/images_without_moderation/courbe-zoe.jpg
We could suppose that given torque is available only for first 30% of speeds w.r.t maximum declared speed, than conisder linear (or quadratic) decrease of torque, or consider instead power values: 0 to Pmax in first 30%, constant P=Pmax for remaining 70%.
Specifically for this picture:
First 30%: T=220 Nm, P=6.3x
Last 70%: T=0.022 x^2- 5.2x + 357, P = 63000W
But torque at maximum speed is not usually an available data, so quadratic approximation of torque is not usually available and we must rely only on power curve.
