Calculating 10% NaOH eqv. to 10% NH4OH
  • Thread starter Thread starter Delicieuxz
To create a NaOH solution with neutralizing power equivalent to a 10% w/w NH4OH solution, it is essential to understand the molarity of both solutions. A 10% NH4OH solution consists of 10% ammonia and 90% water, providing a specific amount of dissociated OH. While both solutions can neutralize acids similarly through stoichiometry, NaOH releases additional OH ions as it dissociates, leading to a higher pH. This difference means that while the neutralizing capacity can be matched, the resulting pH of the NaOH solution will be significantly higher, especially near the neutralization point where pH changes rapidly. Proper calculations involving molarity and concentration conversions are necessary to achieve the desired neutralizing effect without causing pH spikes.
Delicieuxz
How to calculate 10% NH4OH eqv solution of NaOH, taking into consideration extra OH?
Hi, I'm wanting to make a solution of NaOH that has the same neutralizing power per quantity as 10% w/w NH4OH. Given that a 10% solution of both will have an equal amount of dissociated OH, but that NaOH will release additional OH as it is consumed, how should I go about this? Thanks.
Chemistry news on Phys.org
I'm not quite sure what you mean by "a 10% solution." In order to answer this question, you must first know the molarity of the solutions you want to use.
This is an acid dissociation problem, usually covered in general chemistry 3. If you're not familiar with dissociation constants and equilibrium, it could be a bit confusing for you.
10% NH4OH, 90% water, w/w. I'd like to know how to make a solution of NaOH that has comparable neutralizing power, without resulting in PH spikes from additional OH that is released.
No problem with preparing solution able to neutralize identical amount of acid (simple stoichiometry and concentration conversion problem, similar to the ones explained here: http://www.titrations.info/titration-calculation, you just need to convert molarity to percent concentration), but you can't expect identical pH, it will be much higher in the NaOH solution.
You must have the NH4OH solution and the NaOH solution reversed. There is no pH spike during neutralization, just a smooth transition from basic to neutrality. Near the neutralization point the pH changes rapidly though. Perhaps that is the spike you are referring to?
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
