Calculating Current Through a Parallel Resistor Circuit: Help Needed
The discussion focuses on calculating the current through a resistor in a parallel circuit with two other unequal resistors. Participants explore the application of Ohm's law in this context, seeking clarification on how to approach the problem given specific resistor values and voltage.
  • Homework-related, Technical explanation, Conceptual clarification
  • One participant asks how to find the current through R1 in a parallel circuit with given resistor values and total voltage.
  • Another participant suggests using Ohm's law to find the current through each resistor.
  • A participant questions whether Ohm's law applies similarly in parallel and series configurations, expressing confusion about the differences.
  • One participant hints that the original poster may have too much information for the problem at hand.
The discussion does not reach a consensus, as participants express varying levels of understanding and confusion regarding the application of Ohm's law in parallel circuits.
Participants do not clarify the assumptions regarding the circuit configuration or the application of Ohm's law, leaving some steps and reasoning unresolved.
jenzao
How do you find the current through a resistor that is in parallel with 2 other nonequal resistors? I totally forgot how to do this.
as an example, if
E = 10V
R1= 5ohm
R2 = 10ohm
R3 = 15ohm
So, I know that 1/Req = 1/R1 + 1/R2 + 1/R3 = .533ohm
and also know Inet = 10V/.533ohm = 18.76A
but how do i get current going through R1?
please help, and thanks
PS --this is NOT a homework question even though i post a lot of HW questions
You have the voltage and resistance, just use Ohms law.
So you use ohms law for each resistor and doesn't matter if its in parallel or in series with other resistors? (thats what's confusing me)
Hint: You have too much information.
  • · Replies 24 ·
  • · Replies 38 ·
  • · Replies 21 ·
  • · Replies 18 ·
  • · Replies 52 ·
